Old 02-21-2023, 12:24 PM   #1
Fla.Marco
Default Strange brakes
Anybody have any idea how to stop the front brakes from dragging? It's not a lot of drag but it's not like Lamb brakes that don't seem to even touch the rotors at all when the wheel is free spinning.
Fla.Marco is offline   Reply With Quote
Old 02-21-2023, 12:47 PM   #2
Mark Ugrich
Liked 71 Times in 38 Posts
Default Re: Strange brakes
contact strange, i believe they have an o ring kit for the caliper pistons that will reduce or eliminate drag.
Old 02-21-2023, 01:55 PM   #3
John Dinkel
Liked 263 Times in 68 Posts
I have put springs between the brake shoes to push them apart.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 02-21-2023, 03:14 PM   #4
Jim Caughlin
Liked 805 Times in 245 Posts
I did that also, doesn't take much of a spring, just something to make sure the pads retract away from the rotor.
Jim Caughlin is offline   Reply With Quote
Old 03-13-2023, 12:08 PM   #5
Fla.Marco
Where does the spring go? Is it on the bolt that holds the pads in place?
Old 03-13-2023, 12:53 PM   #6
johnk1872
Liked 15 Times in 10 Posts
yes
johnk1872 is offline   Reply With Quote
Old 03-13-2023, 07:21 PM   #7
Regan Wilson
Regan Wilson's Avatar
Liked 134 Times in 70 Posts
What is it really worth in ET? Just a question. The way I've always understood brake drag is that the little bit of bearing clearance would work it out. Please correct me if I'm wrong.
Regan Wilson is offline   Reply With Quote
Old 03-14-2023, 02:42 PM   #8
curtis reed
Liked 125 Times in 59 Posts
Don't know if these would work but I just saw them posted on another site.
https://nucap.com/drt/
curtis reed is offline   Reply With Quote
Old 03-14-2023, 02:56 PM   #9
Mike Gray
Mike Gray's Avatar
Liked 692 Times in 200 Posts
Those are the same as the OEM springs on my Nissan Titan.
Mike 7570 A/SA
