Old 05-09-2023, 11:16 AM   #1
Mark Ugrich
Liked 71 Times in 38 Posts
Question Custom AN fittings
Is there anyone making custom AN fittings? I could use a 90 degree bulkhead fitting but with a longer straight side in -10.
Old 05-09-2023, 01:02 PM   #2
Kenney Kelley
Liked 72 Times in 36 Posts
Default Re: Custom AN fittings
Is this what you're looking for ? Jegs # 110264
Kenney Kelley
Kenney Kelley is offline   Reply With Quote
Old 05-09-2023, 03:02 PM   #3
Andy Friar
Andy Friar's Avatar
Liked 226 Times in 76 Posts
I didn't search for the specific fitting that you are looking for, but as another source, Parker has a huge selection of all types of fittings.
https://divapps.parker.com/divapps/t...n/select-shape
Andy Friar
Andy Friar is offline   Reply With Quote
Old 05-09-2023, 04:04 PM   #4
Mark Ugrich
Kenney Kelley
That’s the correct type of fitting.What I need is the long end to be able to pass through a 1” wide piece of square tubing.It’s really hard to tell from the pictures how long that end is, but it may be worth a try.
Old 05-09-2023, 09:59 PM   #5
Kenney Kelley
I also looked at the Allen Aircraft Catalog and i didn't see anything long enough that would work because most of the time i've used those fittings on high pressure panels that the material is only 1/4" at the most. You could call Allen Aircraft and see if maybe they have a suggestion.
Kenney Kelley
Old 05-09-2023, 10:10 PM   #6
Mark Ugrich
Kenney Kelley
Thanks , I’ll give that a shot.I’m kind of surprised one of the AN manufacturers hasn’t addressed this.It’s basically just a through the frame bulkhead.
Old 05-09-2023, 10:28 PM   #7
Larry Merk
Larry Merk's Avatar
Liked 314 Times in 113 Posts
You might try contacting one of these fellows. They make and sell a lot of AN hoses for aircraft. One of their specialties is making custom fittings. They had separate companies, thus the differing email addresses, but have joined forces recently.
Aircraft Specialty Flightlines
https://www.aircraftspecialty.com/
Steve: AIRCRAFTSPECIALTY@GMAIL.COM
Tom: TSFLIGHTLINES@GMAIL.COM
Larry Merk
Larry Merk is offline   Reply With Quote
Old 05-11-2023, 04:58 PM   #8
SSDiv6
https://www.anhosefittings.com/10an-...90-degree.html
Old 05-11-2023, 09:24 PM   #9
Mark Ugrich
Thanks for all the replies. I truly appreciate your help.
