Liked 55 Times in 29 Posts
I currently have a Holley black pump and the standard Holley regulator. I have a Quadrajet carburetor. The pump seems fine , but what would y’all suggest for an upgrade on the regulator?
Liked 225 Times in 136 Posts
Just remember the more surface area the regulator has the smoother the regulator will bee.
Liked 1,943 Times in 584 Posts
I have a similar set up as you do. I have a Magnafuel 2 port regulator on my car right now. It works good. That being said I hear the the Product Engineering bypass regulator is supposed to be a big improvement for the Q jets, So if you plan to upgrade you might take a look at the Product Engineering regulator.
Mike Pearson 2485 SS |
I have run my same setup for years with no issues, but now I have the same motor in a heavier car with fresh air induction opposed to a lighter car with a flat hood. I now seem to have a fuel supply issue. I am hoping to get some more flow with a larger-better-less restrictive regulator. The Holley is 3/8 in and out, not sure if I should go 1/2 in 3/8 out or 1/2 in and out.
Liked 535 Times in 110 Posts
Jeff: We have Aeromotive on my Olds and my son's Camaro. His is a bypass and mine's a deadhead style. With a Q-jet, I run -10 from the cell to the regulator and -8 from the regulator to the carb. If I had to do it all over again, I would consider the Product Engineering unit for Q-Jet like Mike suggested.
Jim Kaekel 3836 STK |
Jim, I am glad you replied. We have the exact same combo. Did you ever run the standard Holley regulator and did you ever have any fuel issues with that setup?
Liked 2,487 Times in 698 Posts
I run a Holley regulator on most of my stockers.
Cheap and easy to service when needed. Never had fuel deliver issues. Better than I can say for my full Aeromotive setup on the Superstocker! It drops from 6.5 to 3 in the last few hundred feet no matter what I change on it!
Liked 704 Times in 281 Posts
I believe I have a brand new automotive 2 port regulator. Can check on saturday
#9 | |
Liked 520 Times in 176 Posts
A few seasons back I switched to a Magna Fuel pump and the Bigger Holley Regulator, I think the part number is #704 and it has a green colored diaphragm which is alcohol resistant. I have 5/8" fuel line from tank to regulator and 1/2" from regulator to carb ( Q-Jet). Checking fuel flow at the carb fitting I can pump 2 gallons of fuel in 30 seconds set at 6 lbs. of pressure. I hope that helps, the bigger regulator has larger diameter orifices internally which should help for fuel flow. This is probably over kill in my stocker but might help your combination. Have a Good Day. Respectfully, Henry Kunz 1534 H/SA |
What is your pressure befor regulator? You need 7.5 lb of pressure per G’s of acceleration just move the fuel to the regulator!
