Old 06-18-2023, 03:37 PM   #51
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
Default Re: SFI flexplate mandatory in all v8s Jan 2024
I have always used a SFI wheel. Just thought it was a good idea.
Bob Bender 144 O/SA
Old 06-18-2023, 03:55 PM   #52
1347
1347's Avatar
Liked 1,026 Times in 281 Posts
This ruling only applies to S/SS cars and I'm not saying that in most cases it isn't a good idea BUT it doesn't apply to a low 10 second bracket car so why should it apply to a "U/SA 273 Mopar" or a P/SA 301 Pontiac that rarely if ever sees over 6 grand?
And where am I supposed to find this 301 Pontiac SFI approved flex plate?
Maybe a re-think and a change to 11.99 or quicker might be prudent?
Maybe a call to our division tech rep, whoever that is right now, or somewhere higher up the ladder will get an answer. i can't really believe if they don't make one, that the answer will be that you need to park the car.
Duane Hoven
1342 SS/GT
1347 is offline   Reply With Quote
Old 06-18-2023, 04:00 PM   #53
L.Fite
Liked 498 Times in 244 Posts
Billy , Just mark your tech card with the ATI 400 Pontiac model.
If anyone asks , I'll say I saw you put it in .
I'm sure you will anyway..it's only a deuce , plus re-balancing
Still not sure if you can add or take away weight on an SFI approved flex.
Anybody?
You CAN...
I have in the past... (removed weight for balance)
Honestly never gave it a thought, just part of building a motor...
Will it recertify?
Don't know...
THAT is the true question...
Hmm...
L.Fite is offline   Reply With Quote
Old 06-18-2023, 05:54 PM   #54
Billy Nees
Originally Posted by L.Fite View Post
You CAN...
Will it recertify?
Don't know...
Hmm...
Soooooooooooooo, "You CAN..." but can you LEGALLY?
Billy Nees 1188 STK, SS
Billy Nees is online now   Reply With Quote
Old 06-18-2023, 06:51 PM   #55
L.Fite
Exactly!
Again, never gave it a thought, just SOP...?
I've been running SFI flexplate since it became a rule way back when.
Have always balanced according to what was needed building a motor.
Also recall having to drill the converter bolt holes to fit the converter bolts?
I can't remember anyone at any time crawling under a car to check if it was even there. Much less if it had any extra holes...
Always ran cars fast enough to require one, so always had one.
I've never seen a flexplate fail like that, (and due to the reaction I don't think it has been a particular problem) although I once saw a stock one spit the balance weight off... that alone will get your attention.
It will be something a lot of people will have to deal with in the off season, not too big a pain really just something else to put on the to do list over the off season freshen up.
Old 06-18-2023, 07:42 PM   #56
4543
Liked 648 Times in 140 Posts
Option will probably be some kind of flywheel shield.
4543 is offline   Reply With Quote
Old 06-18-2023, 08:39 PM   #57
e vassar
Liked 272 Times in 108 Posts
So..is there an expiration date?
I have an SFI flexplate on my car now that I will examine for any cracks etc..but does it make sense to take one off that has never broke,and replace with one that might?
Old 06-19-2023, 12:56 PM   #58
Pat6868
Liked 93 Times in 29 Posts
Does each and every SFI certified product have to go through the required testing to meet the standards. Asking if someone in the know can answer, thanks.
Pat6868 is offline   Reply With Quote
Old 06-19-2023, 01:52 PM   #59
Steve Grady
Steve Grady's Avatar
Liked 153 Times in 51 Posts
A representative sample of the actual product is tested. Product is then considered SFI compliant for that part number. Any changes requires retesting.
Div 3 Sales, Service and Tech for many manufacturers
Steve Grady is online now   Reply With Quote
Old 06-19-2023, 01:55 PM   #60
Steve Grady
SFI 29.1 Flexplates have a 3 year certification time limit. Some brands will recertify if you send it in to them. Check with manufacturer.
