Old 07-11-2023, 10:38 PM   #1
jkblade
Liked 8 Times in 6 Posts
Default Remote Filter AN Size?
I'll be adding a remote oil filter to my car to make it easier to change, SBC at 7800 at the stripe. Would a #10 line be ok or should I go with a 12? Thanks
jkblade is offline   Reply With Quote
Old 07-17-2023, 06:22 PM   #2
Jim Caughlin
Liked 768 Times in 235 Posts
Default Re: Remote Filter AN Size?
Pretty much every application I have ever seen is #10.
Jim Caughlin is offline   Reply With Quote
Old 07-18-2023, 02:48 PM   #3
CMcAllister
Liked 887 Times in 246 Posts
Pay attention to port sizes, and fitting and adapter IDs.
-10 hose is not helpful if you have parts in the system with 3/8" IDs.
Old 07-18-2023, 06:02 PM   #4
FED 387
Liked 320 Times in 172 Posts
Also try to keep your hose and fittings as straight as possible and no reduction in all the adapters and fittings--- NO 90*s if you can get away from it and also watch your radius in the hose--A -12 is better but you might be able to get by with a -10 if you use a low restriction "racing " type filter no OEM Walmart stuff------keep an eye on your oil pressure
Old 07-18-2023, 06:47 PM   #5
Ralph A Powell
Liked 225 Times in 136 Posts
We have always used #12 on all our remote filters fo both Ford and Mopar
