Old 07-31-2023, 09:05 AM   #1
Bob Don
Bob Don's Avatar
Liked 905 Times in 193 Posts
Default Transbrake issue
I have a 92 Mustang, 302 FI C4 (reverse valve body w/air shifter) in SS. Had trans rebuilt over the winter. Ever since, transbrake isn't working correctly. Voltage was checked, solenoid works, transfluid pressure was checked. First run of the day everything works fine but on subsequent runs, transbrake doesn't hold and I go through the lights. Happened yesterday again at LVD. Anyone ever have this happen? Valve body issue? Thanks for replies.
Bob Don 128 SS
Old 07-31-2023, 04:00 PM   #2
Keith 944
Keith 944's Avatar
Default Re: Transbrake issue
I had a hipster solenoid roll pin, started backing out, and sometimes it would catch not engage, engage or get stuck. Not sure if your trans brake even has a roll pin in the solenoid but definitely something to check.
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Keith 944 is online now   Reply With Quote
Old 07-31-2023, 10:43 PM   #3
GTX JOHN
In my SS car I had a similia issue.
Turned out that I had a leg strength issue.
I am 75.
I had to lower the pressure switch a lot to
compensate.
John Irving
741 Stock
741 Super Stock
Old 07-31-2023, 10:52 PM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 888 Times in 239 Posts
I have a 92 Mustang, 302 FI C4 (reverse valve body w/air shifter) in SS. Had trans rebuilt over the winter. Ever since, transbrake isn't working correctly. Voltage was checked, solenoid works, transfluid pressure was checked. Firs run of the day everything works fine but on subsequent runs, transbrake doesn't hold and I go through the lights. Happened yesterday again at LVD. Anyone ever have this happen? Valve body issue? Thanks for replies.
Bob it sounds like you have a rear band servo seal that is leaking .It probably works on the first hit because the fluid viscosity has not thinned out yet. how does reverse feel once the fluid is warmed up after the first run?
Old 08-01-2023, 04:06 PM   #5
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,388 Times in 504 Posts
Whose valve body, internal or external trans brake selenoid and does the trans work fine when not using the trans brake? Can you hold it with the foot brake?
'65 Mustang SS/L & L/SA
Bobby Fazio is online now   Reply With Quote
Old 08-01-2023, 10:00 PM   #6
tstickff
tstickff's Avatar
Liked 562 Times in 139 Posts
Also make sure your air bottle has enough C02, might have enough pressure in the bottle first time out but loses air pressure? Maybe an air leak? Consider switching to an electric shift instead of air shift, I did and much happier.
Tim Stickles
Tim Stickles
tstickff is offline   Reply With Quote
Old 08-01-2023, 10:02 PM   #7
nickh
nickh's Avatar
Liked 691 Times in 205 Posts
I am 75.
compensate.
John we ain't old we are just "seasoned"!
Old 08-02-2023, 11:44 AM   #8
Eman
Liked 133 Times in 76 Posts
Go through the lights, I'm guessing you go forward when on the TB. Does it hold at all or does it roll forward as soon as you take your foot off of the brake? I'd check the wiring first to make sure the hot solenoid isn't showing a fault in the wiring. 2 wire solenoid? Where is it grounded?
