Old 08-11-2023, 09:47 AM   #11
Adger Smith
Liked 880 Times in 311 Posts
Default Re: Convertor help
That last post brought up a memory of a customer problem.
He had a major converter trashing.
Put the same part# and brand converter back in it and it was slow.
Like the OP is experiencing.
Finally found the Stator support tube that presses in the front pump had slipped and restricted a hole or two.
An aftermarket stator support aligned properly brought back his good numbers.
Just food for thought...
Adger Smith (Former SS)
Old 08-14-2023, 06:24 AM   #12
hbr509
Liked 3 Times in 2 Posts
Good thoughts guys but shocks in front are lakewood 90/10 and are fine , also the trans has been changed also I have 2 each time and same results , I bought a new front pump from Abruzzi and input shaft still the same, I went to Bradenton last friday with the PTC tighten 500 rpm according to race pak and same results 1.38v 60ft 6.10 et and no rotation on front , I am pulling motor and sending back to Nesbitt for check and freshen up . This is the only thing I have not done yet . I have changed the distributer,coil,msd box you name it its been changed lol. I,m tired Thanks For your help .will keep posted when the motor comes back .
hbr509 is offline   Reply With Quote
