Liked 5 Times in 5 Posts
How does a XS D1600 or S1600 compare to regular 850-1000 amp 12-volt battery?I see the amps are a lot lower on the 16 volt but it being a 16 volt is it going to give as much cranking power than the 12 volt? Will it have to be charged anymore? I have a super stocker with no alternator. Any opinions would be greatly appreciated thanks jason
#2 | |
Liked 1,930 Times in 580 Posts
Mike Pearson 2485 SS |
Liked 124 Times in 42 Posts
Multiply Volts x Amps to get Watts for a comparison of output for the 12 volt vs 16 volt battery.
Div 3 Sales, Service and Tech for many manufacturers |
Liked 34 Times in 18 Posts
I had 12v on my big block and would break teeth on the flexplate. switched to 16v. spins over like a stock engine would
Ausby Brewington A231 S/G |
#5 | |
Liked 759 Times in 379 Posts
I have always run an alternator and wouldn't race without one. Charging is the same as a 12volt. Every electric motor spins faster...starter, water pump and fuel pump. The only down side is 16volt batteries do not have the reserve capacity that 12volt do, they have a history of working and then not without warning and they are heavy, 47lbs. ![]() ![]() ![]() The dragster now runs a lite weight (8 lbs.) 16v lithium battery ![]() Last edited by 1320racer; 08-16-2023 at 08:42 AM. |
