Old 09-06-2023, 12:02 PM   #171
Steve Stasko
Liked 274 Times in 143 Posts
Default Re: So all of you Mopar guys!
Ya know Billy, getting out of bed in the morning is a "waste of time".
The stick really is the better choice in the Neon. The 41/40TE's are an interesting piece. There is no bands, only clutches. There is an electric solenoid for each gear, and an actuating element that fills with fluid to control each gear change/how many clutches are applied. You would have to write a program to override the fill points on the element to increase the shift rpm, as well as engaging the converter clutch lockup...which can have anywhere from 50-300 RPM worth of slippage depending on driving.
If one really wanted to go the route of running an automatic Neon, I would swap in an A-413 from an earlier front wheel drive car, and do away with the electronics.
Old 09-06-2023, 12:21 PM   #172
mtkawboy
Liked 54 Times in 18 Posts
There's an 05 Neon SE on Facebook Marketplace in Hermosa South Dakota for $150. Its a parts car though, no engine or trans, cheap start though
mtkawboy is offline   Reply With Quote
Old 09-06-2023, 01:30 PM   #173
Billy Nees
Liked 7,783 Times in 1,743 Posts
Originally Posted by Steve Stasko View Post
The 41/40TE's are an interesting piece. There is an electric solenoid for each gear
Kinda like the trans in my Buick.
Billy Nees 1188 STK, SS
Old 09-06-2023, 02:02 PM   #174
Steve Stasko
I'd rather work on the trans in your Buick.
Old 09-06-2023, 02:09 PM   #175
Billy Nees
If there's an "electric solenoid for each gear", couldn't you rig up some kind of electric "shifter" to control what solenoids are engaged and dis-engaged and use it for gear selection and engagement? Just "brain-farting" here.
Old 09-06-2023, 06:03 PM   #176
Cglrcng
Cglrcng's Avatar
Liked 357 Times in 191 Posts
I would second that A-413 swap choice, you can make them live easily, and the gearing choices are there if you look hard enough. Just keep it cool to make it live.
Gary Lucier - 7832 STK. / 7832 E.T. EF/S Slow Sled. I am, but a simple test of your true patience. So, do all the really "Big Wheelies" you can!
Cglrcng is online now   Reply With Quote
Old 09-07-2023, 07:16 AM   #177
Steve Stasko
I don't see why not. Would be interesting to see how people react to that. It would be similar to what they were using in Pro Stock during the 90's to control the Lenco solenoids I suppose.
I will add that I have had some in depth conversation with a Chrysler transmission engineer who didn't come out and directly say, but heavily implied that these transmissions were designed to fail.
Old 09-07-2023, 08:51 AM   #178
Billy Nees
Steve, I've had to deal with Powerglides and later, 200 Turbos. They were junk until Racers got their hands on them and fixed them. Now, they're in everything!
Maybe it's time for a Racer to step up and prove that "Chrysler transmission engineer" wrong.
Old 09-07-2023, 12:46 PM   #179
When we did the Monte Carlo, (3.4 V6 , 3300# , high 13's) I had decided to use a 125 C 3 speed, rather than the electronic OD.
The 125 started life in a 1980 4 cylinder Citation ( X car).
It never failed us at the track, but it tended to wear out final drives.
It was a bunch of work,.. having to fabricate mounts, a bracket for the TV cable ,and a custom right hand axle of the appropriate length.
If the earlier Mopar transaxle is close to a bolt -in deal, I'd go that way.
If not, the later one could probably be controlled by a series of switches. Clutch apply could be firmed up, I would think.
Light car , 4 cylinder shouldn't cause a lot of grief in that department.
Old 09-07-2023, 01:05 PM   #180
goinbroke2
Liked 397 Times in 156 Posts
As far as the solenoids go...(I'll try to be brief) Had a 93 f350 with a 7.3 and the e4od. Broke the planetary so I got another e4od out of a 98. Connectors etc all different.(6 planetary instead of 3 planetaries, much stronger too) I wired the solenoids (to test) and ran the wires up to the dash. Put the truck in drive and nothing. Depending on which switch (or series of switches) I went through all the gears as well as locking up the converter. Even went for a test drive.
So, yes it can be done.
Hassle? Yeah, a bank of 4 switches that you toggle through going down the track?...that would be interesting to say the least in competition!
