Liked 71 Times in 23 Posts
Does anyone know what Ryan McClanahan was DQed for, in the pre race all star inspection.
Monte Howard 3209 STK, 3208 SS Last edited by Monte Howard; 10-13-2023 at 06:42 PM. Reason: Spelling |
Liked 507 Times in 116 Posts
Heard it was wheel base.
68 Chevy11 327 F/S |
Liked 10,715 Times in 2,231 Posts
I always thought the All Star pre race inspection was a correctable inspection.
Liked 355 Times in 80 Posts
They checked Stock and SS Wheelbase after Rd 1 of All Stars.
They Checked after Q2 Carbs, throttle bodies and pumped modified cars. |
Liked 880 Times in 311 Posts
Sounds like Wesley must have worked the event...
They allowed me to correct the wheelbase at a Memphis division race. Problem was I had a front suspension falling apart. Lucky for me they checked the wheelbase. Rolled the car forward and it got short... Rolled the car back and it got long...
Adger Smith (Former SS) Last edited by Adger Smith; 10-14-2023 at 01:45 PM. Reason: add |
Liked 1,877 Times in 577 Posts
Curious, what would the advantage be in a longer/ shorter than stock wheelbase be? Or is it possible offset? Rollout?
Keith,
Extended roll out if one side is offset. How is it offset? One side at wheelbase specs minus allowance and the other side offset farther would be great for rollout. You could go the other way too. one side a lot shorter. Cover the beam as long as possible. Start the clocks with the wheel the farthest back and stop the clocks at the finish line with the wheel most forward. Make your side of the track shorter than the other guys... Simple, Aye
Adger Smith (Former SS) |
If the rear end is not straight with the frame rails the front tires would have to be staggered for the wheel base to check correct. "Maximum variation from left to right: 1 inch."
Guest
Posts: n/a
They are stock suspension, they move big time. I saw this not more than a month ago on a new 4 wheel alignment. What I measured was not what it showed us! ! I was off an inch!
These cars are getting hammered round after round with wheelies. It will not stay! I assumed it was the stocker, i missed! Last edited by Barry Polley; 10-17-2023 at 04:05 PM. |
Liked 33 Times in 11 Posts
What you state Barry may be true for 50+/- year old stockers but the front wheel drive conversion superstock/modified cars are built with a stagger to improve rollout. The purpose-built chassis does not move like the old stuff.
