#11 |
Liked 759 Times in 379 Posts
rock batteries are far from the best. What is the best with the Rock name on it is their the battery charger, same charger as the Moroso and both manufactured by Interacter https://interacter.com/
#12 |
Liked 64 Times in 11 Posts
Does anyone make a 16v load tester? What usually happens is the battery will show 16v but by the time I get to the starting line two batteries will barely have enough to crank and make a run. Voltage but the amperage is gone.
#13 |
if your batteries are only showing 16v when fully charged, they're done and need replacement.
#14 |
Liked 693 Times in 205 Posts
My Turbo Start 16V battery would get so hot you could barely put your hand on it. I scraped them out soon after.
