Old 11-05-2023, 07:55 AM   #1
hrs1326
Liked 19 Times in 10 Posts
Default Stock Eliminator suspension
Looking at the NHRA rule book it states "aftermarket tie rods with Heim joints permitted"
Does that include the front suspension strut/tie rods?
hrs1326 is offline   Reply With Quote
Old 11-08-2023, 12:10 PM   #2
Liked 5,134 Times in 1,958 Posts
Default Re: Stock Eliminator suspension
No.
One of the few things NOT allowed in S/E.
Old 11-08-2023, 12:49 PM   #3
MR DERBY CITY
Liked 8,116 Times in 1,531 Posts
Better double check that Mark, I thought it was allowed when NHRA also allowed the stock Elim roll bar to go thru the dash and into engine compartment .. Disclaimer …. My memory is not what it used to be.
Old 11-08-2023, 06:26 PM   #4
L.Fite
Liked 497 Times in 243 Posts
SUSPENSION, FRONT
Must retain complete stock front suspension system as
produced by manufacturer for body used, aftermarket tie rods
with Heim joints permitted. Lower control arm may be machined
for larger shock diameter and mount. Lift kits/travel limiters
prohibited. Sway bar optional. See General Regulations 3:4.
L.Fite is offline   Reply With Quote
Old 11-09-2023, 08:26 AM   #5
Billy Nees
Well, it DOES make it easier to fix "bump-steer".
Billy Nees 1188 STK, SS
Old 11-11-2023, 08:45 AM   #6
Coleydog
Liked 53 Times in 38 Posts
If I heard right, one long time stock racer I talked with said the QA1 strut bar was allowed now on his car (Demon).? Back to square one if not allowed.
Old 11-11-2023, 12:06 PM   #7
SSDiv6
You are good.
SUSPENSION, FRONT
Must retain complete stock front-suspension system as
produced by manufacturer for body used. Lift kits/travel
limiters permitted. Sway bar optional. Aftermarket tie rods with
heim joints permitted. Lower control arm may be machined for
larger shock diameter and mount. Strut rods with heim joints
or spherical bearings permitted.
Electric shocks prohibited.
Old 11-11-2023, 12:14 PM   #8
You are good.
SUSPENSION, FRONT
I stand corrected then.
I know, when I was helping out a bit on the Tbolt, about 6-7 years ago, they weren't allowed. That was source of movement that was not good.
Some of you might have noticed a bracket car or two with bad bushings. Seeing the front wheels move back and forth while staging was a REAL safety issue.
Old 11-11-2023, 03:57 PM   #9
SSDiv6
Mark,
You are correct!
It took NHRA some time to understand it was a safety issue, especially after a wheelstand.
As I understand, it was Troy Olsonawski who brought up the issue with NHRA and the actual risk.
Old 11-11-2023, 05:32 PM   #10
Coleydog
Great news, with mine now there is no movement front and back when wheels are in air back to normal height. A lot of time went into fixing that and the bump steer.
