Old 01-15-2024, 10:02 AM   #121
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Accusump - pros & cons
Billy, despite those that have derailed this discussion with personal attacks on me and only replied to do so, it’s still a forum discussion where people reply with their opinion and my last post is relevant to the merit of using an accusump and yes, of course the OP as well as anyone else doesn’t need anyone’s approval nor their engine builder’s blessing to spend their money on their car to install whatever they deem necessary which begs the question why the OP even asked if he only wants to read opinions that are inline with decision to use an accusump, just do it!
Old 01-15-2024, 10:12 AM   #122
Barry Polley
Guest
Posts: n/a
Originally Posted by JGrossijr View Post
David Reher of Reher Morrison:
"One of the best investments a sportsman racer can make for a wet-sump engine is an oil accumulator such as an “Accusump.” An oil accumulator is a sealed cylinder that contains a floating piston. Pressurized air on one side of the piston forces a reserve supply of oil into the engine if the flow from the internal oil pump is momentarily interrupted. An accumulator works automatically and requires virtually no maintenance except regular cleaning. Unfortunately, accumulators are seldom seen in drag racing. That’s a pity, because they really work."
https://rehermorrison.com/tech-talk-...-engine-alive/
I think this pretty much sums it up. An engine builder only sees what the dyno tells them. The user sees G’s plus and minus with angle. As mentioned before hard braking can throw oil forward away from pickup and wheelies can do the same. So many combinations out there it just depends on the car and combination.
When used as a pre oiler after extended periods of sitting I think that's a great option all by itself. I don’t crank a motor after sitting for long periods , I remove the distributor and prime it. Some folks can get away with it, I can’t.
Old 01-15-2024, 10:28 AM   #123
1320racer
1320racer's Avatar
wheelies and hard braking no problem, no accusump
Old 01-15-2024, 10:35 AM   #124
Barry Polley
Guest
Posts: n/a
You also have a custom oil pan ( describe your pan) and priority oiling. Correct?
Old 01-15-2024, 10:42 AM   #125
1320racer
1320racer's Avatar
I have an aftermarket moroso oil pan like thousands and thousands of racers, not custom and I have no greater "priority" oiling than a COPO, Drag Pak or Cobra Jet factory stocker has and most of them too do not use an accusump.
Old 01-15-2024, 10:45 AM   #126
1320racer
1320racer's Avatar
stock block
Old 01-15-2024, 10:51 AM   #127
1320racer
1320racer's Avatar
just a few of the thousands of stock and super stockers running without an accusump, some with engines built by some of the best, courtesy of Bobby's interviews...
Old 01-15-2024, 11:08 AM   #128
Chevy55
Banned
Liked 179 Times in 89 Posts
So what are the disadvantages of an Accusump?
Chevy55 is offline   Reply With Quote
Old 01-15-2024, 11:11 AM   #129
1320racer
1320racer's Avatar
as I already stated in post #9, nine days ago... band aid for an oil control issue, unnecessary cost, added weight, difficulty packaging/placement but lets stay with the thousands of stock racers, a few of which I showcased that don't run an accusump.
Old 01-15-2024, 11:44 AM   #130
Barry Polley
Guest
Posts: n/a
Those are custom pans with priority oiling and basically Superstock from the factory! Not production stock parts. Factory race parts. Apples/oranges
Stock pans I’m talking. Copo , well thought out baffled race design from the factory not production stock parts required and yes you can modify
