Old 01-15-2024, 11:46 AM   #131
Barry Polley
Guest
Posts: n/a
Default Re: Accusump - pros & cons
Originally Posted by Chevy55 View Post
So what are the disadvantages of an Accusump?
Exactly ! None!
Old 01-15-2024, 11:50 AM   #132
Barry Polley
Guest
Posts: n/a
Originally Posted by 1320racer View Post
I have an aftermarket moroso oil pan like thousands and thousands of racers, not custom and I have no greater "priority" oiling than a COPO, Drag Pak or Cobra Jet factory stocker has and most of them too do not use an accusump.
I bet it has a deep sump and better baffling room than a stock pan. How many quarts?
Old 01-15-2024, 12:37 PM   #133
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
again, this isn't about me nor my cars, it's about these cars and the thousands like them that don't run an accusump!
just a few of the thousands of stock and super stockers running without an accusump, some with engines built by some of the best, courtesy of Bobby's interviews...
Old 01-15-2024, 12:47 PM   #134
Barry Polley
Guest
Posts: n/a
Wait what??
I'm well aware of stockers running even less oil than their normal 1 quart low. I'm also well aware of losing oil pressure when driving the stripe and I'm also well aware of the thousands of racers including stockers that do not, have never, run an accusump,
( myself included.
Old 01-15-2024, 01:36 PM   #135
1700camaro
Liked 226 Times in 115 Posts
Originally Posted by Barry Polley View Post
Thank you guys!
He doesn’t understand that this forum and others work as intended.
They work as intended in other ways also. The different forums remove, put in time out & ban the trolls. It may take some time, but it will happen as it has on numerous forums. "He" has a bullseye on his back & brings it on himself.
1700camaro is offline   Reply With Quote
Old 01-15-2024, 01:37 PM   #136
1320racer
1320racer's Avatar
wait why again did you reply to this thread? Answer to engage me not to answer the OP's question.
Old 01-15-2024, 07:51 PM   #137
SS3860
Liked 165 Times in 56 Posts
The Jim Grosse Corvette has an accusump on it.
SS3860 is offline   Reply With Quote
Old 01-15-2024, 07:55 PM   #138
CMcAllister
Liked 920 Times in 259 Posts
I wonder if Barton, Patterson Elite, BES, Line, Tilburg tell their customers they must run an accusump on the engines they build? I know they don’t because I have friends that run engines from all these builders!
I don't know what these guys tell their customers, or not, but I know people with engines from a few of those shops who do run them. And would likely take them off if told to.
Old 01-15-2024, 09:13 PM   #139
El Duderino
Liked 48 Times in 20 Posts
You have friends? I find that very hard to believe
El Duderino is offline   Reply With Quote
Old 01-15-2024, 11:35 PM   #140
tstickff
tstickff's Avatar
Liked 561 Times in 138 Posts
Your a clown and should be embarrassed, you have made yourself look like a complete idiot…congrats!
Tim Stickles
tstickff is offline   Reply With Quote
