#21 |
Liked 759 Times in 379 Posts
so your feelings are hurt by my reply to Don, but his feelings aren't.
At least be honest, your feeble comments have nothing to do with my reply to Don and everything to do with the fact that you don't like that I don't race stock/super stock yet I'm allowed to opine on this forum. That said, this thread nor my reply is about Don's honor. ![]() Last edited by 1320racer; 01-25-2024 at 02:29 PM. |
#22 | |
Liked 502 Times in 130 Posts
For class racing 1/4 mile I would have an issue with spotters at top end.....The grid with ARC clearly is a no/no for actual class racing, For non class racing and testing: I can see where it could add a function of safety and be a useful training, and testing tool, and would help keep someone from crashing, which is always bueno. My guess is that 99% of any illegal activity in stock and superstock is under the hood and not to be found further down car........
Eric Merryfield 1883 STK |
#23 |
There is no rule prohibiting spotters
#24 |
Liked 449 Times in 98 Posts
I had not heard of the ARC referenced above so I looked it up. For those that don't know what the MSD ARC linked with the Grid can do, this is from MSD's website:
"OVERVIEW Now there is even more control with the PN 7761 module for the Power Grid System Controller. This module sets rpm limits based on slew rate (rpm acceleration) or based on time since launch. All of this is programmed seamlessly in MSD View. The ARC module stands for Advanced RPM Control, it basically allows your race car to remain consistent, pass after pass, controlling your engines rpm curve during a pass. This helps you get down the track quicker and far more consistent. By using the MSD View software we can control the rpm down to a hundredth of a second and control the driveshaft speed for maximum traction. We can also pull out timing for a split second should we encounter tire slip. Set 3 different timing Retard curves and a Rev Limit Curve to control wheelspin." Nice video explaining the system here: Basically, it appears you set the driveshaft rpm curve in the Grid for a given ET, dial in and like magic you run within a hundreth of your dial in. Last edited by DG; 01-25-2024 at 03:50 PM. |
#25 |
Liked 459 Times in 90 Posts
I know I will receive hate mail but, GET RID OF THE GRID in Stock
Bob Bender 144 O/SA 2010-2012 National Record Holder |
#26 | |
Liked 346 Times in 126 Posts
#27 |
Liked 7,733 Times in 1,739 Posts
General Regulations; 8:3 and 9:2. It isn't legal the way that I read it.
#28 |
Liked 1,032 Times in 368 Posts
I pulled on the scales one year during TT's at the US Nationals. At the time they had hired some young guy to look at electronics. He looked under my car and noticed a drive shaft sensor. He ask me where that was going to. I told him the ECU. I was busted. He had me take it off and hand it to him the next time I came across the scales. At the time ARC was not invented, but I was informed it's always been against the rules to tie your engine management to a counter (Drive Shaft Sensor). If there is no recorder (Racepac), there should not be a drive shaft sensor on the car. ARC will not be of much use without some way of counting speed/distance. I have installed many ah systems for S and SS guys and usually Drive shaft sensor comes up. I always relay what happened to me and I always get the same reply "The heck with that then" !
Jeff Niceswanger 3740 SS |
#29 |
Jeff, the way that I've always understood it, if you have a "data logger" (racepack), you can't have anything between it and your ignition box. The Grid goes between your "data logger" and your ignition box and lets them communicate with each other.
If I'm incorrect, I'm sure someone will let me know.
#30 |
Hi Billy. I think the original intention of that was so you didn't have to buy multiple sensors for each system.
