Liked 166 Times in 46 Posts
'70 402-375 Stocker Motor. 1971 4 bolt main 454 block, sleeved back to 4.185 bore. The block is not filled. Lifter bored. Steel GM crank, dimple rods, JE pistons, Comp Cam, Shubeck lifters. I never broke one, but I never used a 2 step. Stefs Oil Pan, the newer 291 heads, 359 intake manifold, ATI lightweight Super Damper. Cylinder Heads were new out of the box, no acid, no grinding. This engine will go through an NHRA tear down with the piston out. Made 604 horse on the dyno. Went 10.20's in my B/SA Nova @ 3460lbs. It has about 50 runs on it since it was freshened. $7,500. I am in Sulphur Springs Tx. PM me if interested.
Liked 42 Times in 23 Posts
604 with iron heads is impressive, if you need one buy it!
Jim I'm interested in your stock eliminator engine can you give me a call .
Leonard Trahan 832-499-3431 I race in division 4 , 417B |
