#41 |
Liked 759 Times in 379 Posts
20 years, no leaks, no fitting failures and now retired. That's the performance and duty life you get from American made products and from a leader in the industry. You'll never get that from Chinese JUNK!
#42 | |
Liked 115 Times in 35 Posts
Thanks for the info! |
#43 | |
Liked 931 Times in 265 Posts
They are a bit more cost effective than most other US made stuff. People have budgets. They seem to be mostly in stock at the regular places while others have been a bit spotty as far as certain things being available at times. Frustrating when you can't get a particular piece to match what you are already using. They offer many odd, peculiar, non-standard parts, pieces and configurations which come in handy for particular situations. Just my observations. |
#44 |
Liked 127 Times in 61 Posts
I have used some of the Brown and Miller crimped end hoses and you simply will not find a better hose or fitting. Their convoluted PTFE hose will bend smaller radii than any other brand of Teflon lined hose. They are in no way cheap though.
I have also used XRP and although they are a fantastic brand they are a step below in comparison to the Brown and Miller stuff. JMO https://bmrs.net/ |
#45 |
Liked 1,867 Times in 436 Posts
I bought some stainless line kit from Amazon
Same kit summit sells $60 less Seems like most vendors use China anyway It is what it is American is ruined by the big box stores All in
james perrone 1290 STK |
#46 |
Liked 62 Times in 17 Posts
I've always used steel line as much as possible because I like working with it. I'll need to pay closer attention to the braided flexible connections though. Thanks to the OP for the heads-up.
#47 |
#48 | |
Liked 45 Times in 32 Posts
As foir what brand lets just say it is a very popular brand mentioned here. Bottom line is parts fail, sometimes stuff gets by QC, it happens. I am not looking to throw anyone under the bus. |
#49 |
Liked 609 Times in 140 Posts
It was mentioned upthread that the fuel was the problem. I agree.
Think about it - there are all sorts of grades of fuel, but do you have any idea of what they're made up of? Or because of the universal move to cost cutting if those chemicals have changed over time? I used to work in an industrial setting working with pumps and piping that carried very nasty liquids, including one that would melt glass. There are a LOT of polymer materials available because different chemicals attack different things. The different versions are made to withstand different things. So it is not out of the question that the liner breakdown could be eliminated, though it's highly unlikely it ever will be. You have to know what you're working with, and only the fuel suppliers do. They're not going to share their secrets. |
#50 |
Liked 239 Times in 94 Posts
Rubber inside the hose rots and the braid hides the cracks. I used to get hose free off a friend that worked at a helicopter place. They change the hoses on a scheduled basis.
But five years seems to be all that is safe unless you use Teflon lines. I got a 25 ft roll of 1/2" steel line and -8 fittings from Summit and ran two 12 ft lines from the pump to the regulator up front and a return. |
