Old 03-21-2024, 05:49 PM   #1
ron b
Liked 4 Times in 4 Posts
Default minimum slick to leaf spring clearance
I am running a mickey thompson 29.5 x 9 st slick and was wondering what the minimum clearance between the slick and the leaf spring with the car sitting on the ground. thanks ron
ron b is offline   Reply With Quote
Old 03-21-2024, 05:52 PM   #2
David Lee
Liked 346 Times in 126 Posts
Default Re: minimum slick to leaf spring clearance
radial or bias?
Old 03-21-2024, 05:57 PM   #3
ron b
Bias
Old 03-21-2024, 06:24 PM   #4
1700camaro
Liked 226 Times in 115 Posts
With our radials we have 3/8" clearance & have no issues with rubbing.
While it has been many years since we have run bias slicks. It seems like we had about 1/2" clearance, but also had signs of slight rubbing. I'm sure it was due to turning off at the end of the track & sidewall flex.
1700camaro is offline   Reply With Quote
Old 03-21-2024, 07:41 PM   #5
T Ames
T Ames's Avatar
Liked 125 Times in 33 Posts
Currently operating Hoosier 9x29 bias ply with about 3/8-1/2 inch clear of the leaf spring. Typically inflated to 12-15 psi on a 9 inch rim. Seems to work fine. The inboard white letters aren’t so white anymore but attribute that to minor rubbing during turns-like 1700camaro alluded to.
T Ames is offline   Reply With Quote
Old 03-21-2024, 08:36 PM   #6
jmcarter
jmcarter's Avatar
Liked 3,184 Times in 973 Posts
All sounds like good guidance, assume you’re running a 10 inch rim?
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 03-22-2024, 07:11 AM   #7
ron b
currently running a 9" rim.
