Old 03-27-2024, 10:28 AM   #1
Greg Barsamian
Liked 425 Times in 97 Posts
Default Vega Pitman arm for GM”A” body
Looking for suggestions or part # application for a Pitman arm to install a Vega steering box in a 1970 Chevelle, SS
TIA
Greg
Old 03-27-2024, 11:54 AM   #2
Henrys Toy
Liked 520 Times in 176 Posts
Smile Re: Vega Pitman arm for GM”A” body
TIA
Greg
Good morning Greg and to all,
I believe Flaming River builds & sells steering box's , Vega style - you might want to try contacting them. I know they used to sell parts through Jegs and could be another outlet to try.
Hope that helps.
Have a Good Day.
Respectfully,
Henry Kunz 1534 H/SA
Henrys Toy is offline   Reply With Quote
Old 03-27-2024, 12:43 PM   #3
Jeff Stout
Liked 704 Times in 281 Posts
Default Re: Vega Pitman arm for GM”A” body
Speedway has two styles. A straight and a bent one. Not sure if they work for A body
Old 03-27-2024, 07:11 PM   #4
Greg Barsamian
Hope that helps.
Have a Good Day.
Respectfully,
Hi Henry, I purchased the following parts from Flaming River
1- FR1500 Steering Box $560.00
1-FR 1722 Upper joint $102.50
1-FR 1715 Lower Joint $100.50
1- FR 1850-22 Steering Shaft $90.00
Total Spent $860.00
Tech Department at Flaming River wasn't much help, They told me my existing "Pitman arm" would work!
Not even close!
Thanks for the Reply!
Old 03-28-2024, 10:34 AM   #5
MAURICE BLENDHEIM
Liked 284 Times in 87 Posts
Greg... Contact Rare Parts Steering and Suspension in Stockton, CA. They will "steer" you in the right direction. MB
MAURICE BLENDHEIM is offline   Reply With Quote
Old 03-30-2024, 12:37 AM   #6
Eman
Liked 133 Times in 76 Posts
Is the shaft for the pitman arm smaller than the hole in the pitman arm? I used an S10 box on my 85 F body and pitman arm worked. You might need an arm from a manual steering Chevelle.
Old 03-30-2024, 06:18 PM   #7
Greg Barsamian
Thumbs down Re: Vega Pitman arm for GM”A” body
UPDATE: B/SA Bob Moran "modified" a new "Straight" Vega Pitman Arm, and a "used" pitman arm from a Monza to make it fit.
Furthermore the upper "DD" Joint that was sugested to purchase was the wrong size!
fortunately for us, Milt @"Westgate Performance" in Freetown MA. had what we needed "IN STOCK" in order to complete the installation........
Old 03-31-2024, 02:41 PM   #8
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Sounds like a huge PITA to lose a few pounds.
