Old 04-02-2024, 11:51 PM   #1
MLP
Liked 23 Times in 7 Posts
Default SS GT hood scoops
Hello all,
I was wondering if someone was building a GT out of a old body with a modern engine what scoop rules apply? In this example, both the car in question and the engine package out of the guide had hood scoops available. So would it be legal to run the proper scoop for the car in question?
Marc Lapoint
MLP is offline   Reply With Quote
Old 04-03-2024, 01:36 PM   #2
340Cuda
Liked 805 Times in 341 Posts
Default Re: SS GT hood scoops
From the rule book:
If using a model car that has a factory fresh air hood, but the engine combination is a non-fresh air engine, the openings must be blocked off. Non fresh air engines = No openings. Fresh air engines with fresh air hood permitted.
Old 04-03-2024, 01:42 PM   #3
MLP
Originally Posted by 340Cuda View Post
From the rule book:
I thought that was the case, thanks!
Marc Lapoint
Old 08-29-2025, 03:02 PM   #4
pfordamx
Liked 7 Times in 5 Posts
Would you please define fresh air hood. Or is it simply the availability of fresh air to the engine? Or do they separate ram air cars an example would be is a 400 from a ram air judge considered a fresh air engine.
pfordamx is offline   Reply With Quote
Old 08-30-2025, 06:09 PM   #5
SS/AM
Liked 21 Times in 7 Posts
Even if the scoop opening needs to be blocked off, it might an advantage due to a better intake manifold design.
SS/AM is offline   Reply With Quote
