Liked 346 Times in 126 Posts
going a differ combo
Liked 2,516 Times in 701 Posts
Are they flat top or with valve relief or either
way? I never raced that year as I hate 2 Brl carbs.
yes, they are flat tops. but it seems the same pistion set can work from 68 to 88. if you pm your paypal amount, i will send the payment asap
You are fine and can pay me when
I deliver them to you! I am at Vegas races until after next week's divisionals. If you need them sooner = I can try to get home and ship them to you after Nationals.
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 04-11-2024 at 01:58 PM. |
I did some checking and the 68 to early 70s pistons have
4 VALVE notches similar to 72/73 340 engines. You need to use them rather than flat tops or you will have nearly zero valve clearance with a stocker camshaft with correct lift. Sorry I did not know the early engines had a different piston.
[QUOTE=GTX JOHN;695987]I did some checking and the 68 to early 70s pistons have
4 VALVE notches similar to 72/73 340 engines. You need to use them rather than flat tops or you will have nearly zero valve clearance with a stocker camshaft with correct lift. Sorry I did not know the early engines had a different piston.[/QU ok, guess i will just have to go with the ross pistons. the class whides to not mention the valve reliefs Last edited by David Lee; 04-11-2024 at 09:14 PM. |
