Old 04-21-2024, 04:44 PM   #31
Jrh5220
Liked 30 Times in 19 Posts
Question Re: 402 stocker engine
Originally Posted by B Parker View Post
Not sure why you are doing this on your own. The first time you had this problem you should have brought your entire engine to the shop and let them figure out what the problem is. We all could guess at 20 different things it could be but until you bring it somewhere good you could hone this block right into new sleeves. I'd call the guy 5 post up and ask him if he has time to look at it. It's great to say you did it yourself or you don't have the money but at some point you need to stop the bleeding. BP
Well BP I had worked in a engine shop for several years, I just thought may be someone else had ran into the same problem.
Jrh5220 is offline   Reply With Quote
Old 04-22-2024, 06:53 PM   #32
Alan Nyhus
Liked 799 Times in 236 Posts
Default Re: 402 stocker engine
Jim, when you say they are race rings...are they AP steel.coated rings, a barrel faced back cut moly, etc?
"That'll never work....."
Old 04-23-2024, 05:44 AM   #33
Henrys Toy
Liked 520 Times in 176 Posts
Smile Re: 402 stocker engine
Good morning to all,
Something Alan said struck me, as we might be looking at this all wrong. What kind of an oil pump are you using? The reason I ask is it possible that the oil pump in pumping a great deal of oil up to the rocker arms and flooding the valve cover area and I'm going to guess that you aren't using a valve stem seals on the exhaust valves. If you have excess oil in the valve covers and you don't have exhaust valve seals, while the engine is running the puffing through the breathers could be caused by oil blown back from the exhaust stems.
Take a valve cover off and remove the distributor and install an oil pump priming tool. Put a 1/2" drill on it and spin it up, then observe the amount of oil being pushed through the pushrods and out the rocker arms. You might be surprised how much oil can flow through there. I have a Schumann pump in my engine and it does a VERY Good job of oiling the engine. When I first primed my engine the oil shot out the rockers like I never saw before. I had to restrict the oil flow and got that under control.
I'm not saying that's your problem, but lets assume just for a moment that with the pistons and rings being new and good quality and you've had this engine apart a couple of times, maybe its not the rings or pistons or even the cylinder sleeves. but we're looking in the wrong place.
I still believe you should put this engine on a dyno at this point and put this situation to rest. On a dyno you'll also know just how much Power this puppy makes. The best of luck on you're search here, keep us informed as to what your conclusion is.
Respectfully,
Henry Kunz 1534 H/SA
Henrys Toy is offline   Reply With Quote
Old 04-23-2024, 03:06 PM   #34
Alan Nyhus
While the #401 heads are notorious for poor oil drain back, the haze from the lifter valley area (coming up from the crank case) doesn't fit with that either.
Tough to diagnose stuff like this long distance. If the leakage numbers are in fact fine, the dyno is where you'll find the answers.
Old 04-23-2024, 05:42 PM   #35
Jrh5220
The rings were from Greg L and they were back cut. The pistons were cut for the rings at cp. 12 lb oil ring..
Old 04-23-2024, 06:02 PM   #36
Jrh5220
Cool Re: 402 stocker engine
Al it’s not like I havent done this before ,the heads are 291 cast iron they have never been on any motor but this and a427 I ran. Matt hone it last time I followed his recommendation on assemble. I upped the oil ring from 12 to 14.5 no help. It does look like an oil temp problem but what is causing it ?.?the only time I have seen this it was the cam going flat.Its not.
Old 04-23-2024, 08:23 PM   #37
Oil temp is not hard to measure, you can put a cheap sending unit in the drain plug.
Old 04-23-2024, 09:02 PM   #38
Alan Nyhus
Al it’s not like I havent done this before...
Didn't mean to offend you, Jim...just trying to pull out some info (ring material, etc).
Wishing you all the best as you work through it. -Al
Old 04-24-2024, 03:54 AM   #39
Rick J
Liked 73 Times in 37 Posts
The part that doesn't sit right with me is that it sat for 3 years, and somehow became a smoker
Rick J is offline   Reply With Quote
Old 04-24-2024, 01:34 PM   #40
Jrh5220
You didn’t Al
