Old 04-25-2024, 06:16 PM   #21
MR DERBY CITY
Liked 7,999 Times in 1,526 Posts
Default Re: current cost of having good stocker head work?
Originally Posted by B/S 428 View Post
Wow, thanks for the disrespectful slam, never mind that I build everything on my car, rear end, rollerized trans, custom cylinder hone and ring pac, heads and seat work by me along with carb, 20 years of working on it, I went from running mid 15s to a best of 12.90 at 101 with a .355 lift cam so yeah it's been a gift...21 Wallys and #1 indy 2022 Ive never worked so hard to go so slow.
Brian Seaberg 627
You are to be commended for doing everything on your car. Additionally, qualifying Numero Uno at INDY is quite an accomplishment.…..
MR DERBY CITY is online now   Reply With Quote
Old 04-26-2024, 01:36 AM   #22
Justin Graham
Justin Graham's Avatar
Liked 515 Times in 72 Posts
my Comet runs pretty good.
I concur to the "pretty good", I've seen it! Great run at LV Class Finals Brian!
My best guess Professor would be the cost depends on the actual head being serviced. Unless some thing has changed, I was quoted by a great head builder $3500 for 305s to be done.
7350 Stock Eliminator
Quite possibly the only member to REDLIGHT their join date
Justin Graham is offline   Reply With Quote
Old 04-26-2024, 01:44 PM   #23
B/S 428
Liked 154 Times in 34 Posts
Thanks Justin, I know it's not for everyone but all of this can be done for the cost of parts, all in for everything on my heads under $1000 I have a old portable Souix valve seat grinder that I works fine, of course the hours add up, 20-40 hours on a set of heads and 20-40 hours on a short block..this includes CC combustion chambers and runners, the only thing I don't do is deck/ mill heads or bore block..
B/S 428 is offline   Reply With Quote
Old 04-26-2024, 04:12 PM   #24
nolongerracing
Liked 72 Times in 27 Posts
$1000. in parts??
Someone earlier said that $250 per hour was flat rate at a good repair shop and you spent 20 to 40 hours on your heads, wouldn't that add up to $5000. to $10,000. labor??
So, what's the problem with the quotes you are getting??
nolongerracing is offline   Reply With Quote
Old 04-27-2024, 02:07 PM   #25
MR DERBY CITY
Originally Posted by Alan Roehrich View Post
Ask MJ Quinn how I know all of this.
By the way, MJ, missed you at the combo on Sunday.
I was actually in Bowling Green on Saturday to see my granddaughter’s high school play. Man, I sure miss racing but some things in life just aren’t meant to be. I also miss the guy in the Black Stetson !!!!! :
