Old 05-30-2024, 07:06 PM   #1
JerryHancock
Default Looking for Wrist Pins
Looking for a set of 876x2.250x.090 wall.need the oversized pins as the pin bores are a bit worn. Have tried Trend,Patterson, Precision and BME with no luck. Any ideas?6
JerryHancock is offline   Reply With Quote
Old 05-30-2024, 10:58 PM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: Looking for Wrist Pins
I would call JE---Mahle--Manley ----Directly see if they can help you--FED 387
Old 05-31-2024, 02:18 AM   #3
Rick J
Liked 73 Times in 37 Posts
If no luck with the above, Precision Products in Arden, NC will make them in house to your specs.
Rick J is offline   Reply With Quote
Old 05-31-2024, 08:42 AM   #4
Ralph A Powell
Liked 225 Times in 136 Posts
Trend
Old 05-31-2024, 10:05 AM   #5
Angelo DiTocco
Angelo DiTocco's Avatar
Liked 189 Times in 48 Posts
You could have the pins chromed to make up the differences and then hone the pin bores to the proper clearance.
Angelo DiTocco
'98 Firebird SS/HA
'98 Firebird B/SA
Angelo DiTocco is offline   Reply With Quote
Old 05-31-2024, 01:14 PM   #6
pmrphil
Liked 348 Times in 152 Posts
Make sure you specify either spirolox or wire locks.
As said, try Mahle or Manley
Phil Molski
PMR Performance
S/C 1623
Old 06-04-2024, 10:53 PM   #7
JerryHancock
Thanks Class Racer. Found some 879.at Trend
