Liked 997 Times in 201 Posts
Has anyone used the ceramic brake shoes from the outfit in TX. called Praise Dyno? They have a kit with ceramic shoes, bigger wheel cylinders,and better springs.Hey I know I should be putting disc brakes on it.
Guest
Posts: n/a
Hey Lynn, dont bother. I put the whole kit on my car. The rear wheel cylinders leaked instantly, and the fronts blew out after the car sat for the winter. The spring kits are the same you can buy at Napa. The wheel cylinders also are the same bore size as stock or what I can buy at Napa. ( The reason I know this is that I am a counterman at a Napa part time, and I looked this stuff after I had the problems) I had to buy a set of fronts about a month ago, and bought a set of Bendix and the were the same as what this guy sold. My stopping power with the kit is no better than the best grade shoes you can buy localy. If I had to do it over I would have bought a set of shoes line with a softer material or Carbon fiber. If you have any questions contact me. I run the same kind of car you do with drums all around. It was just a big waste money and time, just my take.
#3 | |
http://www.cottonsperformance.com/products.asp?cat=52 |
thanks for the info.
Liked 43 Times in 29 Posts
Hey Lyn
I installed the complete kit on my 68 Camaro and couldn't be more happier. The brake system works just as they stated. I can hold the car at the line without creeping at 3000 rpm and the car stops very well. By the way I installed their system almost 3 years ago. I believe the secret to not having any kind of leakage is to always start with clean brake fluid. If you do decide to go with Praise Dyno Brakes Make sure your entire system is flushed of any old fluid.
Mark Ruset 2048 STK |
another question. Is there a original style master cylinder for the GM A bodies that is better to use than the stock size one? thanks Lyn
for a 1971 Buick GS
Liked 64 Times in 14 Posts
You all might try calling Roger at Lamb he is the brake guru....
Mark Callanan 1027 STK |
#10 | |
.....I think Lyn wants the low budget approach... ![]() |
