Old 07-17-2024, 12:04 PM   #21
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Brake Question
centering the pads in the caliper relative to the rotor, rotor runout as well the type of bearings, preload on them, type and quantity of grease and seal is how you get your front wheels to spin longer AND it's worth nothing on the time slip. But that's a different discussion for another day.
Old 07-18-2024, 07:57 AM   #22
curtis reed
Liked 125 Times in 59 Posts
Also making sure the caliper is parallel to the disc not just centered.
curtis reed is offline   Reply With Quote
Old 07-18-2024, 09:45 AM   #23
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,387 Times in 504 Posts
We are very particular about this and what 1320 mentioned above. Has anyone run DR97 pads front and rear? Does anyone have a certain microswitch they use for high gear to shut off the two-step power? The shifter is Precision shifter forward pattern. Thanks.
'65 Mustang SS/L & L/SA
Bobby Fazio is online now   Reply With Quote
Old 07-18-2024, 01:27 PM   #24
Kirk Morgan
Liked 81 Times in 45 Posts
I have mounted a switch with a lever on it so when you go to high gear it interrupts the power to the pressure switch. Bobby i have put a few on RJs car. He may even have one. I will do some research on it. The switch would have to normally closed type.
Kirk Morgan is offline   Reply With Quote
Old 07-18-2024, 01:42 PM   #25
Kirk Morgan
Amazon has them. You want one with 3 wire hook up.
Old 07-18-2024, 04:13 PM   #26
Bobby Fazio
Yes It would be a normally closed that opens when switched. I just want to see how they are mounted on a shifter.
