Old 07-18-2024, 12:00 PM   #1
Eman
Liked 133 Times in 76 Posts
Default Master cylinder pressure question..
Other discussion about MC's and the mention of a MC with 60/40 bias.
Someone explain to me how the MC can have 60/40 bias when the bore in the MC is the same size for both pistons/ports.
I know GM used some step bore MC's where the pistons are different sizes for each port which makes sense using hydraulic principles where the same pressure is applied to 2 different size pistons results in different pressure out of the ports.
Old 07-18-2024, 01:14 PM   #2
pmrphil
Liked 348 Times in 152 Posts
Default Re: Master cylinder pressure question..
The positioning of the "cups" are staggered, which changes the timing of the application of pressure
Phil Molski
PMR Performance
S/C 1623
pmrphil is online now   Reply With Quote
Old 07-19-2024, 11:35 AM   #3
Eman
Might delay application but it sounds like many think the pressures are different, including the tech guy at the company that sells them.
Old 07-19-2024, 12:03 PM   #4
pmrphil
They will be different, due to the compression on one side versus the other - start compressing later would result in lower pressure.
Phil Molski
PMR Performance
S/C 1623
Old 07-19-2024, 12:08 PM   #5
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Pressure can only be increased by changing the pedal ratio or by decreasing the master cylinder bore.
Old 07-22-2024, 10:23 PM   #6
James Packer
Liked 3 Times in 2 Posts
The bias is likely volume not pressure.
James Packer is offline   Reply With Quote
Old 07-23-2024, 12:03 PM   #7
Eman
How does it put more volume to one port? Same bore size operated by the same pedal stroke.
Old 07-24-2024, 09:09 AM   #8
L78 Nova
L78 Nova's Avatar
Liked 23 Times in 13 Posts
The piston is elongated with a chamber in the middle section. The forward chamber is pressurized by the front of the piston, full bore diameter.
The middle chamber is also pressurized but has reduced area due to the middle diameter of the piston carrying across to the forward piston. At any given pedal force, reduced pressure is generated in the rear chamber.
L78 Nova is offline   Reply With Quote
