Old 07-21-2024, 06:04 AM   #1
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Default Metric T-200 issue
Metric T-200, reverse valve body. Trans shifts fine 1-2 but 2-3 shift does not shift solid and rpm flares momentarily....once it shifts, 3rd gear is ok
At the moment I don't have a playback tach configured to visibly confirm this and am going by what I hear.
I just raced this car for the first time and it's one I owned back in 2005-2007 and have driven a couple times back in 2011. Never recall having an issue like this.
Don't know who built the trans in the car and does not have E-shift.....
I have to re-check the fluid level but thought it was ok.....
Since it's a reverse shift pattern, it can't be a a shifter cable adjustment issue in my thinking
Any ideas from T-200 users ?
Rich Biebel
S/C 1479
Stock 147R
Old 07-21-2024, 12:26 PM   #2
Signman
Liked 269 Times in 99 Posts
Default Re: Metric T-200 issue
Had this issue with my first 200 changed builders much reduced
Trans builders will know more was told this is something that is inherent.
Would think fluid pressure others will know more.
Old 07-21-2024, 12:37 PM   #3
Terry Cain
Terry Cain's Avatar
Liked 231 Times in 107 Posts
Had an issue like this with a TH350. Seems it was dropping RPM at shift and getting back on converter. Took me several weeks to figure it out.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 07-21-2024, 07:18 PM   #4
SS3860
Liked 165 Times in 56 Posts
I had a similar issue, only with the 1-2 shift. Ended up being the wrong dipstick tube. I only thought it was full.
Tom Flowers
E/SA. 3860
SS3860 is offline   Reply With Quote
Old 07-21-2024, 07:52 PM   #5
Angelo DiTocco
Angelo DiTocco's Avatar
Liked 189 Times in 48 Posts
Do you have a trans cooler? or a loop
Angelo DiTocco
'98 Firebird SS/HA
'98 Firebird B/SA
Angelo DiTocco is offline   Reply With Quote
Old 07-21-2024, 09:04 PM   #6
Rich, Who's valve body is it?
I'll PM you my number in case you don't have it.
Old 07-21-2024, 09:10 PM   #7
Jeff Stout
Liked 704 Times in 281 Posts
Mark you told what to do on my 200 because being a heavy car. That was making full pressure in drive.
Old 07-22-2024, 06:59 AM   #8
Rich Biebel
I’ve talked to the previous owner about the issue.
He says it’s always done it and I do know who does transmissions for him but don’t know what valve body he uses.
I spoke with 2 other metric users and their experiences with this issue and more importantly the builders that do them and their units do NOT do it.
There is no trans cooler
I will check the fluid later today and see what it looks like
I pretty much am stuck with what I have for now and will make some calls about future possibilities.
Rich Biebel
S/C 1479
Stock 147R
Old 07-22-2024, 08:52 AM   #9
Henrys Toy
Liked 520 Times in 176 Posts
Smile Re: Metric T-200 issue
I?ve talked to the previous owner about the issue.
He says it?s always done it and I do know who does transmissions for him but don?t know what valve body he uses.
Good morning Rich and to all,
I have a McClay unit in my car currently and it does not shift like that. You being in North Jersey you might want to reach out to Sepanick Transmissions or Leon M. ( sorry for miss spelling ) and they should be able to get you fixed up. You might also want to speak with Mark Yac.as he is a wealth of information on these units. Not having a ton of personal experience with these units myself - it could be a fluid level issue, maybe pan not baffeled. Maybe be valve body or clutch clearance issue, the Servo piston and band , even the direct clutch. If you haven't dropped the pan already, you might want to look inside and see if there is clutch material in the pan. I'm guessing to look over the basic's and go from there.
Respectfully,
Henry Kunz 1534 H/SA
Henrys Toy is offline   Reply With Quote
Old 07-22-2024, 09:08 AM   #10
Rich Biebel
Those I’ve talked to with Sepanek built units say theirs do not do it
I will do some checks on it starting later today.
It does have a cast aluminum pan on it and it’s always possible the fluid level is not right.
The biggest problem with running one of these transmissions is knowledgeable builders are few and far between and the waiting time to get one I’ve been told can be considerable.
Rich Biebel
S/C 1479
Stock 147R
