Old 09-03-2024, 03:37 PM   #11
Mike Pearson
Mike Pearson's Avatar
Liked 1,916 Times in 574 Posts
Default Re: Cast crank for Super Stock?
I ran cast cranks in a couple of my super stock small block chevy engines. Never had a problem with them. I have broke 2 aftermarket steel cranks. Both of those broke because other parts broke first.
Mike Pearson 2485 SS
Old 09-03-2024, 03:48 PM   #12
Jim Cimarolli
Liked 166 Times in 46 Posts
I have seen them both break, mostly due to detonation.
Jim Cimarolli is offline   Reply With Quote
Old 09-03-2024, 09:17 PM   #13
Stephen & Horace Johnson
Liked 161 Times in 52 Posts
i ran a 390 cast crank for years .. quickest we ever ran with it was 9.70s?
definetly not using cast cranks these days? it was a ticking time bomb waiting to happen ?
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 09-04-2024, 06:31 AM   #14
Bob F
Liked 16 Times in 11 Posts
A 50oz external cast crank or something that?s been converted to internal balance?
Bob F is offline   Reply With Quote
Old 09-04-2024, 10:53 AM   #15
Stan Weiss
Stan Weiss's Avatar
Liked 733 Times in 384 Posts
How many runs could you get before the crank no longer maged good?
Stan
Old 09-04-2024, 01:44 PM   #16
GTX JOHN
Liked 2,467 Times in 695 Posts
I know several people who have used cast cranks in their 318/340
Superstock engines that run 8000+
I gave them quite a few for free as I do not run them in ours cars.
Most of them have got away from using them anymore.
John Irving
741 Stock
741 Super Stock
Old 09-04-2024, 01:45 PM   #17
Ken Parkman
Liked 9 Times in 5 Posts
It's a 290 AMC, so no aftermarket parts, and pretty much nothing to directly compare. But with a light piston and fairly short stroke I've decided not to worry about it, and mag the crank after a number of passes. These are easy to internally balance.
I think the effectiveness of the damper is one of the biggest factors in crank life, but that's another thing where there is no comparable data.
Ken Parkman is offline   Reply With Quote
Old 09-04-2024, 09:44 PM   #18
the last one i used had 75 runs on it? it was maged good at that time , decided to go 427 shafts ?
