Old 09-09-2024, 09:09 AM   #31
bigshow2966
Liked 181 Times in 56 Posts
Default Re: Fine them and then make it legal. Wowwser
I thought they had the correct pulleys, but the positions were reversed. Big pulley on the jackshaft and small pulley on the blower and it would spin faster.
bigshow2966 is offline   Reply With Quote
Old 09-09-2024, 09:57 AM   #32
Chris1529
Liked 70 Times in 29 Posts
that is what I was thinking reading between the lines.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 09-09-2024, 10:10 AM   #33
onefarmer
Liked 152 Times in 35 Posts
I'm guessing that it would depend on how "tight" you could get the teeth on the belt to hug the jackshaft pulley and how "loose" you could get the teeth to hug the blower pulley and still work. I can't imagine there being a great difference in diameter but........
My understanding is there was 32 nubs on the outside so the counting could be done and the teeth where spaced out where the belt rode to catch the cogged belt correctly, close to 1/2" or a 36 tooth. Pretty smart design as apparently it has been in use since mid season last year and passed tech several times. Looking at all the numbers from the races from last year to Indy is easy to see who all had something extra under the hood in FSS and FX Mph and ET don't lie. We did not run our FSS car after Las Vegas race last fall because we were not competitive there. We laughed and said all year we would have to swap the rear pullies to run the cars in show down . Well now we know that was the truth. We have been working all year trying to get our engines better to make more HP since we were down 4-5 mph with the FX cars prior to Indy. Now we know the 80hp we were looking for was never gonna be found. I believe I lost 3 races last year to pully-gate 2024, and 3 this year. This makes my win at Norwalk this summer all that much more rewarding. My lose to Aaron in the finals at Indy was a legit lose. He clearly out drove me as I brought my worse pass of the weekend to the final. Now since the engine in the car was ran Sunday in Greggs car then switched Sunday night before he raced Alex and I, well that is another story in its self. The rules are the same as Pro-stock, once a engine makes a pass in one car it can not be used in another car at same event. But since the engines were never teched in with the serial numbers as should have been it was left go. Again I guess some people think rules are more of a suggestion then the standard.....
FX L177, FSS L177
STK L177
Lenny Lottig MMPS 77
onefarmer is offline   Reply With Quote
Old 09-09-2024, 11:00 AM   #34
Bryan Worner
Liked 535 Times in 86 Posts
The rules don’t apply to certain people. I’m pretty sure they aren’t the only classes they have “bent” the rules in over the years. They seem to be untouchable when it comes to tech, tear down, etc!
Bryan Worner is offline   Reply With Quote
Old 09-09-2024, 11:10 AM   #35
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Bryan Worner...KNOWS!
Old 09-09-2024, 11:40 AM   #36
SSDA Hemi
SSDA Hemi's Avatar
Liked 451 Times in 77 Posts
Sad at this development all the carnage and drama to fx and fss while this went on. People made decisions based on being down horsepower and losing. Shame on Nhra tech as counting teeth on a pulley, a space on a pulley, even if no teeth are there, should be counted if you didn?t pick up the increased diameter by eye.
How do the Stanfields look their fellow racers in the eyes from here out. This isnt a misinterpretation of the rules. Would be with 2 black eyes if I were in those classes wasting my time and $$$
SSDA Hemi is offline   Reply With Quote
Old 09-09-2024, 11:41 AM   #37
1320racer
1320racer's Avatar
With a smile and business as usual!
Old 09-09-2024, 01:22 PM   #38
FED 387
Liked 335 Times in 182 Posts
Since multiple offenders were in on the scheme perhaps NHRA should mandate that ONLY NHRA STAMPED AND SERIAL NUMBERED APPROVED pulleys may be used. ALL pulleys must be registered as to serial number. The serial number and NHRA logo must be easily readable. Makes no difference on what make of engine being used or the type/brand of supercharger ONLY an accepted pulley is legal. No modifications of any type whatsoever to the pulley can be done WITHOUT NHRA written approval. If the pulley is modified from the OEM specs NHRA will have to approve the modification. NHRA will further keep a record of ALL pulleys and serial numbers as well as who owns them. If the owner/driver/engine builder no longer has the pulley in their possession( car/engine is sold)or the pulley is damaged beyond repair then the pulley MUST be re-registered to the new owner BEFORE it can be used in NHRA competition. Pulleys MUST BE used in the ORIGINAL position that they were designed for such as a lower must be used as a lower an upper must be used as an upper NO SWITCHING positions ALLOWED
IF YOU GET CAUGHT USING ANY PULLEY OTHER THAN A NHRA SERIAL NUMBERED AND REGISTERED PULLEY, the results are : FIRST OFFENSE: Automatic 1 year suspension for the driver and/or the car owner, $10,000 fine payable immediately , forfeiture of all points , all illegal parts will be immediately confiscated. If they are dumb enough to commit a second offense LIFETIME BAN for the driver and the car owner in NHRA activities plus a $25,000 fine payable immediately.
Do you think this might stop it??? FED 387
Old 09-09-2024, 01:22 PM   #39
James Perrone
Liked 1,863 Times in 435 Posts
As it has been said before
Don?t ask for permission
Ask for forgiveness
They knew better than to ask.
Grey area REALLY!
james perrone 1290 STK
James Perrone is online now   Reply With Quote
Old 09-09-2024, 07:49 PM   #40
CopoCommodore
Liked 2 Times in 1 Post
As a fan from Down Under I find it difficult to believe a few things.
1. The NHRA didn't specify the OD of the pulleys (as well as tooth count) to ensure this didn't happen. (Or the temptation there to explore a grey area of the rules) I am sure there are other classes with toothed belts that have explored this in the past and NHRA would have closed the loophole?
2. Specify the pulleys had to be marked and manufactured by Magnuson, or have an NHRA approval number on it.
3. Inspect these critical components after every pass with fuel and weight, considering it is a 10 second job to measure the OD with a Vernier and count the teeth to see if there is any distinctive gaps between the teeth.
4. Question why covers had been put over the rear drive belt (covers were mentioned in this thread earlier) as the cover is there to hide something and not protect the driver when there is a windscreen and firewall between the driver and the pulleys.
This has tarnished my view of racers and engine builders that I look up to in the /FS, /FX world as I have built my GM car using the /FS rules as inspiration.
CopoCommodore is offline   Reply With Quote
