#21 | |
Liked 734 Times in 385 Posts
Maybe if you really understood dynamic compression ratio, I would take you seriously! ![]() Without knowing anything about your car. How would anyone know what you might need for a SLR? I will need even touch this. ![]() Stan |
#22 |
Liked 759 Times in 379 Posts
keep spewing your misinformation and myth Stan no one with a clue takes you seriously
#23 |
Liked 403 Times in 158 Posts
I laughed so hard at this I almost spit my tea out!!!! LOL!!! Yeah, Stan doesn't know anything about cars/engines/head flow/LOL!!!!!
Jim Miller 103 U/SA |
#24 |
Clearly not but you think he does, no surprise.
#25 |
Lets look at Dynamic Compression Ratio a little closer. It is based on engine parameters and IVC. So unless you have done something to have these change once the engine is running it is really now static. People look at Cranking Compression PSI and running cylinder pressure and say see see the DCR has changed. No what has changed is the engines VE / mass air flow. There have been OEM manufactures that actually call this trapped CR and listed it as an engine spec.
Stan |
#26 |
Let’s not! Start another thread about meaningless DCR. Meanwhile this thread is about rear gear, more of which the OP needs.
#27 | |
So peak HP is @ 6700 RPM and he said he is crossing the strip @ 7100 RPM. So just how much rear gear would you like him to run? As I, and other have said he needs a 3 speed trans. Stan |
#28 |
Liked 16 Times in 11 Posts
800 rpm fallback.
Mast m311 Cyl head 273 runner Last edited by Bob F; 10-08-2024 at 01:33 PM. |
#29 |
He does not NEED a 3 speed trans, he NEEDS more gear!
from what RPM/shift point? Last edited by 1320racer; 10-08-2024 at 01:59 PM. |
#30 |
7000
