View Poll Results: Agree or Disagree? | |||
Agree |
123 | 96.85% |
Disagree |
4 | 3.15% |
Voters: 127. You may not vote on this poll |
Thread Tools | Display Modes |
Anyone who passes full teardown at Indy, or anywhere, should be awarded the record if they've broken the sitting record. Agree or Disagree?
Addition: This is assuming the 1% backup run requirement was satisfied as well as fuel and weight checked on said runs. Last edited by Bobby Fazio; 10-19-2024 at 03:33 PM. |
Liked 346 Times in 126 Posts
Liked 1,919 Times in 576 Posts
I agree with that.
Mike Pearson 2485 SS |
Liked 1,465 Times in 307 Posts
Good Poll Bobby. All we're talking about is bringing things up to date. We weren't allowed to set records at National Events in the past because the tech people were busy with teardowns from qualifying, then winners and runner-ups, pumping Comp cars and others, and teardowns from protests.
hence, we were regulated to the points meets and National Opens where the tech group would have time to accommodate the record setters. Fast forward to todays reality, where there are little to no teardowns, and it makes perfect sense that if your motor is coming down and you've exceeded the existing record, it is only 2 minutes of paperwork for NHRA to establish the runs as a new National Record. No need for NHRA to have any lengthy meetings, no weighing of pros and cons, there are no cons, JUST DO IT!! J.R. |
Liked 2,719 Times in 959 Posts
I agree.
Liked 685 Times in 204 Posts
Nice! I agree.
Liked 309 Times in 173 Posts
The only problem I see is that they don't always check fuel or weight after every run. Unlike when you claim you are trying a record run.
Liked 561 Times in 138 Posts
If they do tear down at Indy they have checked fuel and weight, that?s the first thing they check.
Tim Stickles |
Liked 459 Times in 90 Posts
Absolutely !!!!!!!
Bob Bender 144 O/SA 2010-2012 National Record Holder |
Liked 223 Times in 73 Posts
Here is an idea, anybody that runs faster then the current national record gets torn down and if passed gets the record. This would put the fear back into passing a teardown and curb the cheating. If the record was at a minimum people would be scared and change to a class that does have a actual record which would make more heads up runs and get combos in line
James Boyce 6052 K/SA Stock National record holder 2015,2018,2 times in 2022,2023 |
