View Poll Results: Agree or Disagree?
Agree 123 96.85%
Disagree 4 3.15%
Voters: 127. You may not vote on this poll
Old 10-19-2024, 07:43 AM   #11
Billy Nees
Liked 7,891 Times in 1,753 Posts
Default Re: National Records Poll
Originally Posted by west coast View Post
Here is an idea, anybody that runs faster then the current national record gets torn down and if passed gets the record. This would put the fear back into passing a teardown and curb the cheating. If the record was at a minimum people would be scared and change to a class that does have a actual record which would make more heads up runs and get combos in line
This makes too much sense but would also take too much time. Back in the "good-old-days" many of the NHRA employees were "volunteers", Now because of government intervention they are all paid, hourly workers and NHRA doesn't want to afford them.
Billy Nees 1188 STK, SS
Old 10-19-2024, 09:14 AM   #12
Frank Castros
Does a $20 to 25K stipend for16 Technical inspectors at Indy sound reasonable?
Old 10-19-2024, 09:47 AM   #13
JGrossijr
JGrossijr's Avatar
Liked 463 Times in 60 Posts
Agree with the poll question, but what's the point of being a record holder anymore? With AHFS in place, being a record holder doesn't necessarily indicate you're the fastest in class. There are more than 65 classes in stock and all but 11 are at minimum. There are more than 125 classes in Super Stock (Crazy) and all but 8 are at minimum. In my opinion, the ability to set records isn't as much of a problem as the penalty for going fast. The only way to take advantage of being fast, is to hide how fast a car is until it's needed in a heads-up race, and then only use what you need to get the job done. It's arguably not a whole lot different than throttle stop racing that so many of us abhor.
I think a better conversation would be how do we incentivize displays of performance capability in Stock & Super Stock.
Here are my suggestions.
  • Qualified fields at all national events. Raise the quotas and qualify 32, 64, or 128
  • Points for qualifying position
  • Pro ladder
  • Lane choice to higher qualifier
  • Points for setting records
  • Points for class round wins
  • Consolidate classes to create more heads-up racing
  • Some kind of award or special recognition for being #1 qualifier
  • Special race for top qualifier points earners
JGrossijr is offline   Reply With Quote
Old 10-19-2024, 10:05 AM   #14
Billy Nees
"The incentive" absolutely has to be there otherwise every Racer will eventually be running "junk" just like me. What "incentive" does NHRA give to Racers to NOT run "junk"? I DO understand the personal satisfaction thing. I've gotten over that.
As far as the "how fast a car is until it's needed" thing, I'm pretty sure that we (the Racers) all know who's fast and how fast they can go.
Old 10-19-2024, 10:06 AM   #15
DG
DG's Avatar
Liked 469 Times in 99 Posts
  • Pro ladder
Agree, but would add that the AHFS needs to be corrected by only adding horsepower when a engine combination has an average in the data base more than 1 second under the index.
DG is offline   Reply With Quote
Old 10-19-2024, 10:12 AM   #16
VE6DRW
VE6DRW's Avatar
Liked 44 Times in 14 Posts
Agree - as long as they make two qualifying passes at the same event with the ETs within 1% of each other. On a representative fastest run of 10.00, that would be a 2nd run no slower than 10.10.
Dave White
NHRA Stock/SS 606
VE6DRW is offline   Reply With Quote
Old 10-20-2024, 07:29 AM   #17
Liked 10,999 Times in 2,263 Posts
I would like to see a record be listed until it is broken.
Old 10-22-2024, 08:05 AM   #18
Adger Smith
Liked 880 Times in 311 Posts
The 8 records in Super Stock
Record vs Index
SS/CA 8.86 10.05 -- 1.21
SS/KA 10.49 11.25 -- .76
SS/BS 8.92 9.65 -- .73
SS/AM 8.00 9.00 -- 1.00
SS/CM 8.88 9.50 -- .62
SS/FM 9.86 10.50 -- .64
GT/QA 10.74 11.75 -- 1.01
SS/TB 8.94 9.90 -- .86
5 of the 8 fall in the AHFS averages
3 are quicker than 1.00
The numbers seem to show that
assuming the records will impact the AHFS is assuming alot.
Only 3 out of the 8had real impact on the AHFS.
These 8 may not be the fastest in each class, but they are the record setters. They put up a number that says "Go faster than this and you will be the record setter"
The list of "Things to do" by JRGrossi Jr. are (IMHO) good reccomendations, with the exception of the number of qualified in the field. In this day and age as expenses increase an all run field seems fair to me. "Qualified fields at all national events. Raise the quotas and qualify 32, 64, or 128" seems to be more "Elitist' rather than an incentive.
Adger Smith (Former SS)
Old 10-22-2024, 03:02 PM   #19
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,388 Times in 504 Posts
Looking for info about Captain Jack and another racer who set records this weekend @ Indy. Would like to give them shout out on tonight's podcast 8:30EST. Also want to make sure their info is accurate for the December issue of National Dragster.
'65 Mustang SS/L & L/SA
Old 10-22-2024, 04:51 PM   #20
JIM MARSHALL
Liked 397 Times in 49 Posts
I know Brian Oakes set the SS/CA record at Rockingham this weekend
Brian and I where the number one qualifiers this past weekend
Jim Marshall 1967 STK
JIM MARSHALL is offline   Reply With Quote
