Old 11-20-2024, 06:39 AM   #1
Rick J
Liked 73 Times in 37 Posts
Default 2009 Challenger 5.9-360/275 Drag Pak
Which manual and automatic tranmissios came in these?
What rear suspension and rear end housing is being used in these in stock eliminator?
Rick J is offline   Reply With Quote
Old 11-20-2024, 10:20 AM   #2
Liked 10,714 Times in 2,230 Posts
Default Re: 2009 Challenger 5.9-360/275 Drag Pak
Torque Flight or racing manual. Dana 60, 9 inch, not sure of the 8 3/4. A four link. The best answer will come from NHRA in writing.
Old 11-20-2024, 11:15 AM   #3
GUMP
Liked 2,354 Times in 554 Posts
Rick,
Do you have the head castings for this combination?
Daren Poole-Adams
NHRA Stock/SS 2007
GUMP is online now   Reply With Quote
Old 11-20-2024, 12:01 PM   #4
Rick J
Originally Posted by GUMP View Post
Rick,
I do, at this point I'm contemplating a direction to take.
Old 11-20-2024, 12:39 PM   #5
GUMP
Cool! I know that those things are really hard to find. I wouldn't contemplate that combination unless I had parts in hand.
Daren Poole-Adams
NHRA Stock/SS 2007
Old 11-20-2024, 04:21 PM   #6
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
All of the 2009 dragpaks were shipped with either a tremec 6 speed stick or a 5 speed automatic, most run a 904 or a 727 on the auto front, 4 speed or 5 speed on the stick front. Dana 60 for the rear, maybe 9 inch now since the 11's or so came with 9 inches new.
Search dragpak build manual, and you can confirm at least the tranny info page 29 all info that was presented to nhra. rear suspension is 4 link.
LC22R Challenger Drag Pak - Part # P5155820
Eric
Eric Merryfield 1883 STK
Old 11-20-2024, 05:49 PM   #7
Paul Wong
Liked 419 Times in 85 Posts
I am on the look for a set of these heads if there are any around available
Paul Wong is offline   Reply With Quote
Old 11-21-2024, 11:33 AM   #8
Tom Goldman
Tom Goldman's Avatar
Liked 882 Times in 236 Posts
2009's only came with dummy transmissions that were mostly warranty returns to hold up the engine, and no rear suspension installed . 904'or 727's are acceptable . I've also did a Jerico setup in one. Here's a link to the correct manual that depicts the accepted 4 link rear suspension dimensions and locations . At the time I built one only the Dana and 8 3/4 were accepted . later cars were built with suspension already done and had a "factory 9" installed
I don't know how closely they scrutinize the 4 link these days with minimal tech .T
They had the one I did up in the air and measured the 4 link against the specs in the book.
Here's the link to the P5155775 manual available from Jeg's Pages 34-36 outline the accepted rear suspension.
https://www.jegs.com/InstallationIns...XGTpFxvFb0sKTy
Old 11-21-2024, 07:43 PM   #9
Thank you Mr Goldman.
