Need a little help with the best spring . I have s spring set with 5 spring different colors and length.
80 g body w / 305 . My problem is the motor wont idle. It acts like it go's rich and dies. I have vary low vacuum so I'm thinking the power valve is opening at idle and dumping fuel. My question is should, I use a tall spring or a short spring or just test till one that works thanks, John Last edited by john billups; 12-21-2024 at 05:21 PM. |
Liked 110 Times in 29 Posts
It is a street car or racecar?
stocker. w/ stocker cam short lift long duration.
Liked 7,965 Times in 1,524 Posts
Could possibly be a vacuum leak ?? Has the intake been removed lately ?
Liked 132 Times in 52 Posts
Spring shouldn’t affect idle. Power piston is tied to main circuit not idle circuit if pulling fuel from main circuit at idle throttle blades are to far open.
Checked for vac leak w/ smoke machine.
As for the pistons. I thinking maybe a little pull over . Well I'll put it back together as it's a backup and work on it next spring. thanks all who chimed in. John B645 |
PM sent
Liked 231 Times in 107 Posts
Put flat edge on top base sitting upside down. Must be good and flat.
Liked 748 Times in 137 Posts
Get a drinking straw, cut it down to about 4? long. Place it in the vent stack
at abslight angle to catch the power piston/primary metering rod hanger arms. Note the length sticking up. Now start the engine. It should pull the power piston down and the straw with it. If it goes down and stays down At ?idle? (yes I understand it won?t idle well on its own but you get the idea) then that?s not your problem. Have you drilled the holes in the primary blades yet? Kp |
Liked 27 Times in 19 Posts
Get rid of PP & rods & block the vac. supply, reduce jet size.
