#11 |
Liked 405 Times in 158 Posts
I run flat lifters and am super paranoid about break in procedure. 50# on the seat and ensure it fires(timing/fuel/fans/etc) run for 30-45 minutes 2-2500 rpm. I have never in my life wiped a cam and don't plan on it now. If I do, it will not be because of me.
Pull the 50# springs and Install correct springs, good to go.
Jim Miller 103 U/SA |
#12 |
Liked 2,493 Times in 700 Posts
My understanding is that the quality of the cast core (If you still use them)
has deteriorated significantly in the last number of years. the "CWC" casting cores are extremely difficult to impossible to find anymore. Dozens of Horror Stories on the forums. If the lifters do not rotate, the cams go flat in a real big hurry!
#13 | |
Liked 1,269 Times in 354 Posts
I genuinely do not understand. If you are trying to say that running flat tappet cams keeps the racing more pure to it's origin and makes the entry level more difficult and punishing to choose that combination, then just say that. I may not like it, but at least it's a fair point. After all, I chose the combination that uses them, now I have sleepless nights because of it. Frankly, I like the idea of using newer technology to improve longevity and my quality of life lol.
Dawson Pauley #2827 N/SA 1980 Malibu SW 2S 305/180 #2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide |
#14 |
Liked 2,361 Times in 558 Posts
I don't think that anyone is being punished. The combinations are what they are.
I feel that a roller profile would most likely be quite a bit more aggressive than a flat tappet. My point in posting is not to push for a change, but to see if it is really an issue. Want and need are two entirely different things...
Daren Poole-Adams NHRA Stock/SS 2007 |
#15 | |
In my very limited experience, flat tappets are fine to stay, but I'm not one that has experienced flat tappet failure...yet.
#16 |
Liked 10,920 Times in 2,257 Posts
To get stuff to live Jerry and I (mostly Jerry) made a break in fixture for our cam and lifters.
#17 | |
Liked 348 Times in 152 Posts
Luckily Mopars have a larger diameter lifter, that's a plus. ![]()
Phil Molski PMR Performance S/C 1623 |
#18 | |
Liked 735 Times in 386 Posts
While they are called flat tappets, they are not, and they need to be matched to the amount of taper on the lobe. Stan |
#19 |
Liked 2,762 Times in 977 Posts
If Charlie Wescott is listening this may be an opportunity for Militia to make some hay.
#20 |
Liked 759 Times in 379 Posts
Frankie, welcome back
