Old 01-27-2025, 04:42 PM   #21
Bobby Lundholm
Liked 127 Times in 49 Posts
Default Re: Class Eliminations
I would like to see every other race with class. Bring IHRA back to the glory days where 100 cars showed up and you won't have issues with class runoffs. IHRA Top Stock and maybe Junior Stock would be awesome.
Bobby Lundholm 3516 G/SA
Bobby Lundholm is online now   Reply With Quote
Old 01-27-2025, 07:23 PM   #22
Matt Welker
Liked 77 Times in 15 Posts
I think it depends on the schedule, lots of great posts/suggestions as they relate to the Nhra schedule. For Ihra, it depends more on track, location, and race quantity.
If IHRA offers class, we are going. We are class racers and NHRA has really diminished that part of S/SS.
Also, Alan, make license cross over easy and membership easy so guys can just show up. That easy process got us to our first Ihra races 20yrs ago.
Matt Welker
Stock 1741, SS/AH 114
www.facebook.com/welkerracing
Matt Welker is offline   Reply With Quote
Old 01-27-2025, 07:38 PM   #23
SDmopar
Liked 209 Times in 50 Posts
2- times in each division. All nitro jams. Q1 for the ladder then class runoffs. All runs count towards AHFS as the current NHRA system.
The only change needed is allow requests for hp reduction.
If less then 2 triggers. -1.0 runs
If average of all runs is less then -0.065. Minimum of 20 total runs
Do a HP reduction.
Sure there will be triggers and HP will be awarded. But with a consistent system combos can also be corrected if over adjusted. Allows everyone to race and make their decisions at the stripe.
Use your existing HP ratings and run autos and sticks together for heads up. If the HP ratings are different from stock to auto spit the difference and make them the same. Simple and straightforward.
Brian Anderson
5058 B/SA 99 Chevy Camaro SS
SDmopar is offline   Reply With Quote
Old 01-27-2025, 08:13 PM   #24
J.R. Haddad
Liked 1,471 Times in 308 Posts
It seems this post has been modified to include AHFS and HP Ratings.
If IHRA wants to keep their life simple, which we want them to do, we don't
want to become more aggravation than we're worth, then the AHFS
should look like this this: over 1.25 under-3.5% Hit. Under -.50 under,
of which records must be kept by individual racer and sent in at year
end for verification-3.5 % reduction. No averages to keep track of, just
easy peasy. No Aspirin required on either side.
J.R.
J.R. Haddad is offline   Reply With Quote
Old 01-27-2025, 08:17 PM   #25
Dirk Olson
Liked 172 Times in 46 Posts
IHRA in the south works, up here in the great white north, no tracks as of right now here it does not work. I have hopes that in the future that will change, so we will see.
Dirk
Dirk Olson 5036 STK
Dirk Olson is offline   Reply With Quote
Old 01-27-2025, 08:24 PM   #26
joe huestis
Liked 409 Times in 113 Posts
At least at 2 events per year in each division.
Joe Huestis
Youngsville, NC
Old 01-27-2025, 08:33 PM   #27
SDmopar
J.R.
The benefits of the current NHRA AHFS system is it takes care of any mineshaft weather events simply. And looks at a sample of all the cars across the country.
Main point is welcome IHRA yes we want Class eliminations and let?s simplify it so we can get more heads up runs.
Brian Anderson
Old 01-27-2025, 09:32 PM   #28
MR DERBY CITY
Liked 8,111 Times in 1,531 Posts
Back in the day, did not IHRA follow NHRA s lead regarding HP factors ?…...not sure we can use AHFS and IHRA in the same sentence. This would be the perfect time for Michael Beard to chime in ….
Old 01-27-2025, 10:14 PM   #29
SDmopar
Back in the day, did not IHRA follow NHRA s lead regarding HP factors ??...not sure we can use AHFS and IHRA in the same sentence. This would be the perfect time for Michael Beard to chime in ?.
IHRA has a great opportunity to learn from NHRA and make improvements. There is plenty of room for both. The racer wins when they are competing for business. More heads up races make for what we all want a true performance based class on an evolving equal playing field. Personal index?s would be great but a lot hassle
Brian Anderson
Old 01-27-2025, 10:34 PM   #30
Rose Racing
Rose Racing's Avatar
Liked 227 Times in 74 Posts
I like the idea for a Top Stock and Junior Stock to start with. and I agree on License,Membership and car number. Make it easy to switch back and forth.
J.T. Rose & Associates U/SA T/SA 302R
Rose Racing is offline   Reply With Quote
