#11 |
Liked 75 Times in 28 Posts
#12 | |
Also, you've got Stocker guys putting up Y/T videos of them never using the clutch after the launch! I'm told that a true clutchless trans is a better deal, but much more expensive. So there ya go...More goodies for the entry level class LOL
"We are lucky we don't get as much Government as we pay for." Will Rogers Last edited by Mark Yacavone; 03-04-2025 at 04:53 PM. |
#13 |
Don't blame everything on the existence of the COPO as your car can use them also .
Jack Matyas 1547 FS/C 2015 Camaro COPO # 62- 2012 Camaro Convertible COPO |
#14 |
Liked 327 Times in 121 Posts
#15 |
Liked 3,204 Times in 977 Posts
Likely came from the other coast…the slope keeps getting more slippery by the moment.
#16 |
Liked 172 Times in 81 Posts
We ran no clutch back in the 60's, broke a lot of parts
Jim Mantle U/V/SA 6632 |
#17 |
Why does the West Coast always get blamed for the rule changes? Or lack of enforcement? We, collectively, seem to do pretty well at Indy when needed.
Jared Jordan 9 B/SA 2024 Jeg's D7 All Star - Stock |
#18 |
Liked 172 Times in 53 Posts
2025 rulebook says that pneumatic, rpm controlled shifters are allowed in stock after Jan 1, 2026
#19 | |
Liked 1,878 Times in 422 Posts
Like Super Stock? They were in Super (0.90) classes and bracket cars before they were in Super Stock. I doubt Super Stock is where they're looking at taking you.....
Alan Roehrich 212A G/S |
#20 |
SECTION 11A: STOCK CARS, DRIVETRAIN: 2, TRANSMISSION, AUTOMATIC
(Page 7) (02/25/2025) Any model transmission, same make as car, with a maximum of three forward speeds (unless OEM equipped with more than three forward speeds). O.D. gear not required, reverse permitted. Transmission case must be OEM or aftermarket OEM replica from a standard, automotive application as found in the Official NHRA Stock Car Classification Guide. Aftermarket case must meet SFI Spec. 4.1. NHRA-accepted adapter plates permitted. Modifications to shifting patterns are permitted, provided full shift pattern is retained. Full shift pattern must include park and reverse. Any gear change must occur as a result of an internal function of the transmission or from direct action by the driver. Lockup converter permitted if OEM-equipped with lockup converter and OEM transmission is used. Otherwise, lockup converters prohibited. Electronic transmission controls for the electric shifting of automatic transmissions to shift via internal function of the valve body only permitted in computer-controlled vehicles only; may shift by RPM or time only, wires for line lock, wheel speed, driveshaft speed or GPS signal prohibited. Otherwise, any gear change must occur as a result of an internal function of the transmission or from direct action by the driver. Pneumatic, electric, etc. controls in all noncomputer-controlled electronic fuel-injected vehicles prohibited. The use of air assisted or electric shifter is prohibited in all Stock applications. Beginning January 1, 2026, RPM-activated pneumatic, electric shifters permitted. Deepened stock or aftermarket transmission oil pans permitted. Drilling of transmission case or rear of engine block to adapt incompatible units prohibited. Functional neutral safety switch mandatory. Transmission brake prohibited. Tailshaft modifications for bushing replacement, or NHRA-accepted aftermarket tailshaft, permitted. Any car running quicker than 10.99 must be equipped with a transmission shield meeting SFI Spec 4.1 Last edited by littlemanjoe; 03-04-2025 at 09:06 PM. |
