#11 |
Liked 565 Times in 70 Posts
Damn, I was there for 10 days and never knew any of this was going on, including the check for blinders. I've got to start getting out of the motor home more.
#12 |
If it is a true part of the body style claimed, like an OEM chin spoiler, there's not much that can be done. But, a fabricated "stripe taker" should no-way be permitted.
Daren Poole-Adams NHRA Stock/SS 2007 |
#13 |
Liked 3,247 Times in 987 Posts
After doing some of the .90 wars for a few years you learn to check the front end of cars you?re not familiar with so for me this is just part of racing. I have a much bigger issue with arbitrary rules put in place by a vocal minority from the NHRA “chosen”, such as no blinders and air shifters in Stock. Blatant favoritism is just one of my “buttons”, and it downplays the role of the SRAC.
Jim Carter 2340 Super Stock 2340 SST/2340 Stock Set another place at the table Last edited by jmcarter; 04-27-2025 at 09:38 AM. |
#14 |
Liked 8,227 Times in 1,538 Posts
#15 |
Liked 708 Times in 285 Posts
Could get a record run with one. Qualifying on ladder can be manipulated by removing or installing.
#16 |
Liked 602 Times in 165 Posts
Seen plenty of them out there over the years. However even in a Comp car that is allowed to extend beyond the front of the car by 7?(?) I believe, the performance advantage was minimal, it was more about triggering the finish line weather accelerating or decelerating at the same point. Not that there wasn?t some ET advantage but it was minimal
#17 |
Liked 32 Times in 9 Posts
Rule book, stock cars section 7 body, no customization or alterations, customization limited to paint only. Seems clear to me!
#18 |
Personally, I’m more concerned about mystery buttons in the interior and cars that stutter and break up in high gear while they miraculously run dead on the dial.
Jared Jordan 9 B/SA 2024 Jeg's D7 All Star - Stock Last edited by Jared Jordan; 04-27-2025 at 12:36 PM. |
#19 |
Liked 4,389 Times in 505 Posts
Just make the finish line beam the same height as the starting line beam and problem solved.
#20 |
Liked 503 Times in 131 Posts
Great point.......could it also be safer as it would eliminate the need/reward for hard braking at finish to take the stripe.......thought provoking.....
Eric Merryfield 1883 STK |
