#41 |
Liked 229 Times in 99 Posts
1320racer (Ed) is just an instigator that will ague about anything while he's sitting in his re liner.
Floyd Staggs 787 SST |
#42 | |
Liked 920 Times in 259 Posts
#43 |
Liked 376 Times in 201 Posts
Just saw this thread repost for the first time JP...was too busy the first time it was posted in Jan 2024 doing what Billy suggested..."more wrenching, less typing" and attempting to get car to DF/S natural class wt. and updating the shifter Winter of 2023/24. Totally missed it, did not read it, did not see it until tonight.
I think you have now seen pics. I have seen you made 1 recently in a half hr. Mine is currently on the garage floor next to the car near 2 jackstands. Still currently legal according to the experts that matter. What the future holds who knows. General Regulations applies to all of the classes unless exceptions are permitted or not permitted by specific class rules, and that G.R. 4.5 has a pre-exception listed, followed by a comma, followed by more data and info pertinent to all other classes (except those in which it is permitted in front of the bumper or furthest forward part of the body). Commas mean something in the English language when used. They are almost as powerful as periods...But, not quite the same meaning. I tested the rule, I won the battle, in some minds I surely lost the P.R. war, in some ways that was fully intentional after my personal investigation of many other cars. A lot of supposition was tested, and I can attest based on clear time slip evidence there is no real performance advantage at all (much less than expected based on guesses, far less that the math showed should be expected at 75mph max over 17 plus seconds and less than 4 thou, or less than you can physically dial a car to in a race...to the hundredth). Has that even been tested in reality....can one post up a dial in that reads 17.326 on the window? Has anyone ever tried it? Personally it does not matter what others think or opine...only what the NHRA Tech officials decided based on the existing ruleset. Looking back hard at a deep dive I never cut such decent lights (not in any way connected to that item), and also broke out in doing so by taking away last move options at the stripe as those tests were with the item in question attached. (A direct cause of the installed item in most cases it appears by most of the data I have available). The further under larger breakouts were due completely to another much larger change since March 10th. (The completion of the Holley Terminator X ECU replacing the Stock 1984 ECM/PM. (It is different by far...It is learning/ I am learning and it is a work in progress). The car is flat different than it used to be...Brackets or Stock Elim. It is not a lot faster yet, but creeping slowly up on it. Only been 3 races so far I have actually been shifting any gears by hand after the last couple of years in Drive. Finding out all over again what it wants and needs takes time. And that is this .430/.430 little cam. I have others, but a couple more improves first need to be accomplished to use them. As far as a beam breaker...others much faster than I can worry about that, (plenty of em out there with some variation of it, and a very vocal few without a clue that they have been in use for a long time, others that have known all along too), as my current experiment is over for now. I will carry it, if the rule stays the same I may use it, I may not. As far as Bracket races. I won with it more rounds than I lost with it just knowing the track was pretty much the same length unless I was on the brakes quite a bit and dipped the nose into the beam 4" sooner. It will free me up again to use both feet and both pedals and less time looking out over the hood tip I cannot see from inside the car. Simply go back to my 6 points of possible reference. Learning how high to actually stall the car (in November when dual class seat time and 41 passes and 22 round wins in 5 days), was worth more than 5 beam breakers ever could be. It might be a consistency factor, but it was no performance enhancer. It was definitely a choice reducer. And it was deemed legal by the rule writers and decides. I just tested what was written in black on white pages.Use at your own risk. And if you do decide to...follow those rules explicitly or run afoul of some others. The body of the car was never altered...period. It complied to G.R. 5.4 explicitly. I will admit, keeping it up in the 3-1/4" Zone when parking in the lanes or on any slope was not easy as the car still has parking brakes I use at all times on the rear (normal stop is neutral or in gear, brakes, set parking brake and it locks it down in sprung position closer to the ground. On the racing surface it is different...dry hop, struts to full extension, light brakes, wait for competitive partner, light rolling and creeping forward to courtesy stage...(hitting the brakes early could dip it into the danger zone of an upper blue rainbow wink...I was warned twice in total since August.The hilarious dual surprising one w/ another racer (wink, wink), wasn't warned at all...we staged up on command and went. Like I said, I am far from alone in using one...in brackets or Stock. If it wasn't right there in the book, and so many using some variation of them upon inspection, I would have asked first. And if it was the 1st one you have seen, you have not looked very hard...or at all. Glad you noticed. They do not enhance, they take away choices. Choices I think I like more in retrospect and hindsight, but it was a good test. Hey, I was giving people a known target to shoot for, that is gone now...I control the moving target again now, just like you do yours. I think JP you need to try yours, while it has been determined legal before it gets changed, and you can judge for yourself. Just watch out for the PR nightmare that could follow from a few. Do it brackets first. Then look around really hard, you will find all kinds of variations. Those are the current silent minority. Some though admitting they have been in use forever though.
Gary Lucier - 7832 STK. / 7832 E.T. EF/S Slow Sled. I am, but a simple test of your true patience. So, do all the really "Big Wheelies" you can! |
#44 | |
Liked 706 Times in 283 Posts
#45 | |
Liked 210 Times in 91 Posts
https://www.nhraracer.com/content/ge...206&zoneid=132
Ray Bassett I/SA 1687, SS/DA 1687 "SuperPro is both", unknown |
#46 |
Liked 693 Times in 205 Posts
SECTION 11A: STOCK CARS, FRAME: 4, GROUND CLEARANCE (Page 10)
(05/12/2025) Minimum 3 inches from front of car to 12 inches behind centerline of front axle; 2 inches for remainder of car, except oil pan and exhaust headers. Any component added to the vehicle other than OEM components that could be considered a performance related device such as a beam breaker is prohibited. See General Regulations 4:5. |
#47 |
Liked 348 Times in 79 Posts
Pat Clemente #1427 B/S |
