Old 04-30-2025, 07:26 PM   #51
JP1738
JP1738's Avatar
Liked 1,211 Times in 340 Posts
Default Re: And you thought air/ electrical shifters in stockers was
So, based on the ruling in Vegas, this is legal, right? I whipped this up in about a half hour here at the shop. I?ll run this by tech at Carolina Dragway at the double D2 National opens this weekend and we?ll all find out for sure.
Dawson Pauley
#2827 N/SA 1980 Malibu SW 2S 305/180
#2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide
JP1738 is online now   Reply With Quote
Old 04-30-2025, 07:50 PM   #52
1matcoman
1matcoman's Avatar
Liked 355 Times in 136 Posts
Talking Re: And you thought air/ electrical shifters in stockers was
Can we get an over / under on this passing tech?
Old 04-30-2025, 08:15 PM   #53
Mr. Pauley - Your work is OK for only taking half an hour but in my seventies era mind ( and i'm the only one to say it ) it just looks WRONG .Also it seems many other racers are reading the rulebook like they are lawyers trying a case - but like many have said - "Stock ain't what it used to be " .Good luck at the double ! !
Old 04-30-2025, 09:01 PM   #54
JP1738
JP1738's Avatar
I?m betting no because I built it to be as egregious as possible. 3 1/4 inches off the ground and mounted directly to the underside of the bumper. My only goal here is to have them ask me to remove it and set precedent for every other class racer that this is not considered legal.
Dawson Pauley
Old 04-30-2025, 09:46 PM   #55
Bobby DiDomenico
Liked 101 Times in 52 Posts
Just curious, is that above the wheel rim if the tire was flat?
This has been a most interesting thread.
Old 05-01-2025, 06:08 AM   #56
tpoh815
tpoh815's Avatar
Liked 28 Times in 11 Posts
Leave it on if it passes tech. Replace rivets with bolts and slot it. Dump hard at the stripe and it will adjust itself!
EX 5-Doorstocker
tpoh815 is offline   Reply With Quote
Old 05-01-2025, 08:11 AM   #57
pmrphil
Liked 348 Times in 152 Posts
Wink Re: And you thought air/ electrical shifters in stockers was
They might tell you it has to be attached to the frame, not the bumper, to be "legal"
Phil Molski
PMR Performance
S/C 1623
Old 05-01-2025, 08:39 AM   #58
Liked 10,721 Times in 2,232 Posts
What will it do to the track under hard braking?
Old 05-01-2025, 09:30 AM   #59
MR DERBY CITY
Liked 7,940 Times in 1,520 Posts
Default Re: And you thought air/ electrical shifters in stocck
Could get interesting loading and unloading car from the trailer …..
Old 05-01-2025, 11:00 AM   #60
J.R. Haddad
Liked 1,469 Times in 308 Posts
We don't get the spectator draw we want at most races. If we all have
these extenders in a similar as the one show here, and maybe some
fabricated from steel, in the evening and late night races we might be
able to put on a hell of a spark show. I don't want want to be one that
hits the brakes and my extender starts digging into the track and finds
an old pipe or cable and has an rapid de-acceleration.
J.R.
P.S. I can think of 10 safety reasons NOBODY should have these things!!
J.R. Haddad is offline   Reply With Quote
