Liked 80 Times in 19 Posts
Asking an age old question but looking for some real experience and or data to back up the questions.
In terms of three speed transmissions out there for SS with trans brake what is the actual ET differences between say the following: Protrans Rossler TH350 Lighted Coan XLT-350 Metric 200 (McClay or Equivalent Builder) A-1 TH350 Lighted ATI Transmissions etc. Before anyone says, I know there are a lot of variables, gear ratio, convertor, etc. but looking for some actual experience out there. I have heard pro-trans is one of if not the fastest, but by how much or was cause the gear ratio was changed to be more ideal for the combination?
Avery G. McLawhorn 2166 Super Stock |
#2 | |
Liked 42 Times in 23 Posts
Liked 1,867 Times in 436 Posts
In super stock.pro trans was always the fastest
Rumor has it the Coan is just as fast or better now The metric 200 stuff you don?t see a lot on the east coast
james perrone 1290 STK |
Liked 2,798 Times in 983 Posts
What can Joel on Joy do to enhance a transmission. Many of the FSS cars at Charlotte had his sticker on the rear bumper.
Liked 24 Times in 11 Posts
Liked 3,252 Times in 989 Posts
Whatever Marshall runs…
Thanks to all that have responded so far. Agree Marshall has a fast whatever.
Wonder how much the transbrake for super stock vs a stocker transmission makes a difference in the ET times mentioned or if it would be the same across the board.
#8 | |
A trans brake usually requires more fluid pressure, more volume, and more friction capacity. A three speed brake is not as quick, clean, or consistent as a PowerGlide brake. As such, a three speed with a brake will almost certainly be slower than one without. I don't know that you'll find a reliable significant difference in ET between the various three speeds, once you get into the $5,000 and up price range. Often there will be more ET advantage in optimizing your combination, meaning converter and gear ratios, than there will be in one three speed over the other. I'd suggest you ask around and see who has the happiest customers from a service and support perspective. That might serve you best. There's also the question of the most affordable gear set options.
Alan Roehrich 212A G/S |
#9 | |
Joel limits the use of the Ford C-4 based on the amount of torque the engine puts out. |
We have run multiple transmissions over the past
well over 30+ years in our Mopar Stock/SS cars. Protrans is always the fastest and most reliable for us over the years.
