Old 05-30-2025, 02:42 PM   #1
outlaw
outlaw's Avatar
Liked 132 Times in 52 Posts
Default Comp cams
Can’t remember anyone know about what year it was when comp flat tappet lifters went to crap. Have older set but not sure if I should use them.
Terry
outlaw is offline   Reply With Quote
Old 05-30-2025, 08:04 PM   #2
goinbroke2
Liked 403 Times in 158 Posts
Default Re: Comp cams
Last year I broke in my stocker cam with a set of new comp lifters. I put lots of cam lube, put springs that were 50# or so on the seat then made sure it fired within the first couple revolutions. Ran for 45 minutes between 2000 and 2500. Let it cool, installed the big springs and no issues. Lots of horror stories so I was super paranoid and made sure everything was perfect before I hit the key.
Not saying it's right or wrong or even if comp lifters are good/bad. I am saying, if I had a new set of lifters, I would run them with the aforementioned precautions.
My $.75 Canadian ($.02 US)
Jim Miller
103 U/SA
Old 05-30-2025, 08:18 PM   #3
outlaw
outlaw's Avatar
All the local engine shops have me worried from comp horror stories. Seems like most started during covid but not sure if before that. Box is dated 2018.
Old 05-31-2025, 10:11 AM   #4
Liked 1,878 Times in 422 Posts
Check your lifters to see that they have the correct 0.002" crown, and a good finish on the face. Then use a good quality molydisulfide lube on the face of the lifter (NEVER on the sides) and the cam lobes. You can also drizzle a good assembly lube over that, and a good quality mineral based oil. Use springs that have no more than 200# OPEN pressure, and about 50#-75# seat pressure. Use a good quality break in oil, Brad Penn, Lucas, Driven, Royal Purple, etc. Have your lash/preload set correctly. Have the engine set up to start the instant you try, meaning the fuel bowls are full, the ignition is properly spark timed, etc. Make sure you have the tools handy to set the timing engine speed, etc., and make sure you can cool it. Start it, make sure it goes to 1500-2500 RPM, vary it every 2-3 minutes, and run it for 30 minutes.
Old 05-31-2025, 10:16 AM   #5
Eman
Liked 133 Times in 76 Posts
I've used 2 sets of Comp flat tappet lifters in the last few years. Both sets were old stock, one hydraulic and one solid. Both engines worked out fine and both still running. I might still have the boxes, didn't know there was a date code on them. Both were broken in on break-in oil, can't remember which brands I used, and soft springs. Hydraulic went to Rotella 15w-40 and the flat tappet is on 20w-50 VR-1.
Old 05-31-2025, 01:20 PM   #6
outlaw
outlaw's Avatar
Thanks for the replies.
Terry
Old 05-31-2025, 04:58 PM   #7
GTX JOHN
The cams have a date on the end of the box.
I only run cast cams from them that are 2019 or
older any more.
On any of the cast cams = Look for "CWC" stamped
into the cam. A lot of the Chinese crap is an inferior
cast iron.
I just do not have the budget for the new billet cams and lifters
for our six stockers.
Just my .02 = For Free!
John Irving
741 Stock
741 Super Stock
Old 06-03-2025, 01:37 AM   #8
Greenlight
Liked 79 Times in 22 Posts
Just to clarify, "CMC" (Camshaft Machine Company), not "CWC". They make the cam cores.
Greenlight is offline   Reply With Quote
Old 06-15-2025, 01:19 AM   #9
Jody Lang
Liked 89 Times in 28 Posts
The good cores I have seen have CWC on them which are the initials of the foundry they are from.
Jody Lang is offline   Reply With Quote
Old 06-15-2025, 09:03 AM   #10
CWC is CWC Textron, the company that made a large quantity of the older, high quality cast cores. Since the OE's no longer order hundreds of thousands of them, there are no longer huge orders for the aftermarket camshaft companies to "tag along" with to get the cast cores at a good price, and, in fact, without the huge orders, it isn't really profitable to manufacture the cores in the smaller quantities. And the aftermarket cam companies have no desire to place huge orders, as they'd have a large inventory, and they want small inventories of "A" movers. That's why they don't even want to keep a full selection of the steel cores for rollers.
This is what happens when these "private equity" groups buy up our suppliers. Those people don't give a damn about us or our hobbies. They care about short term monthly profits.
