Old 06-04-2008, 02:57 AM   #1
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Question Ford FE ?
What's the differance between the 352 & 390 ? Bore & stroke?
Old 06-04-2008, 08:22 AM   #2
StrokerDave
Default Re: Ford FE ?
The 352 is a 4in bore with a 3.50 stroke,where the 390 is a 4.05 bore with a 3.78 stroke
StrokerDave is offline   Reply With Quote
Old 06-04-2008, 01:40 PM   #3
greg fulk
greg fulk's Avatar
Thumbs up Re: Ford FE ?
Thanks!
Old 06-04-2008, 02:11 PM   #4
SSDiv6
...and 428 racers like the 390 block for strength...
Old 06-04-2008, 06:07 PM   #5
Rory McNeil
HUH!??! To make a 390 block standard 428 bore size, you would have to bore it .080" over. I find it tough enough to get 428 blocks with thick enough cyl. walls to go .030", let alone a 390 which has thinner walls t5o start with. On my low 10 second 428 bracket car, I split 2 cylinders last year alone.
NHRA 6390 STK
M/S 85 Mustang
Rory McNeil is online now   Reply With Quote
Old 06-04-2008, 07:48 PM   #6
Bub Whitaker
please elaborate...tell me what you know
Bub Whitaker is offline   Reply With Quote
Old 06-04-2008, 08:40 PM   #7
Philip Saran
Liked 14 Times in 11 Posts
You might want to contact Curtis Couter in Las Vegas, he seems to
have found a way to make 390 into 428 motors live in his D/S Cyclone.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 06-04-2008, 09:10 PM   #8
FED 387
Liked 336 Times in 183 Posts
My sources tell me that you want a TRUCK block!!!! Even tho the dimensions are the same truck blocks were a unique casting much more heavy duty than a passanger car block------No way of knowing either way what is true but it makes sense to me get the truck block!!!! --------------Comp 387
Old 06-04-2008, 09:22 PM   #9
FED 387
My sources tell me to look at website ---428cobrajet.org----------- look for block ID--it gives you a fairly indepth description of what you neecd to know/look for too---comp 387
Old 06-04-2008, 09:26 PM   #10
Bub Whitaker
thanks Fed 387
