Old 07-24-2025, 08:54 AM   #11
johnk1872
Liked 15 Times in 10 Posts
Default Re: Welding tips and bracing of axle tubes for factory 12 bo
i did same thing on my car except made a removable gusset that was adjustable and mounted on back side of the rear
johnk1872 is offline   Reply With Quote
Old 07-24-2025, 08:56 AM   #12
johnk1872
i did the same as troy except made a removable gusset on the back side that was adjustable.
Old 07-24-2025, 10:13 AM   #13
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
I use Nickle Cast 55 stick rods with the flux removed to tig weld the axle tube to the case.
I always pre heat to draw any oil residue out ,clean with acetone then reheat to 250*before welding
Old 07-24-2025, 10:37 PM   #14
Greg Barsamian
Liked 427 Times in 97 Posts
Replaced the factory tubes with DOM (Drawn over Mandrel) tubing. Had a local chassis builder press in the new tubes and weld them to the center section. Once installed he then welded the "Big" Ford housing ends to the tubes.
Old 07-25-2025, 09:34 AM   #15
Frank Castros
Liked 2,741 Times in 967 Posts
The Sorensen's Camaro has a ten bolt!
