Liked 8 Times in 7 Posts
Hey Everybody,
I'm trying to find centerline on 72 GTO With stock frame for measurements Would it be halfway between? Outer rocker panels Center of transmission or transmission crossmember Center of stock frame Thanks, Craig |
Liked 929 Times in 263 Posts
I would drop a string line from 4 or 5 different places on each side of the frame, from front to rear. Obviously use the same point on each side - suspension mounting points, factory locator holes, etc. Mark on the floor and find the center. If they all don't fall on the same line, double check your locations. And hope the car hasn't been hit.
Driveline is offset to the right. Don't recall the measurement but should be parallel with the chassis centerline. |
Liked 66 Times in 31 Posts
If you're trying to find centerline of the body, use a plumb bob from the trunk lock to the floor and the center of the grill to the floor.
#5 | |
Liked 6 Times in 4 Posts
#6 | |
Liked 130 Times in 42 Posts
Liked 314 Times in 177 Posts
Pretty sure the engine centerline is offset to the pass side by 5/8".
I seem to remember that the factory shop manuals had those frame directions in them. If I am recalling correctly then the GTO material should be easy enough to find.
Liked 335 Times in 182 Posts
supposedly in all GM A-Body cars the engine is installed on the centerline NO offset from the factory --HOWEVER the pinion center was offset 1/2 inch to the passenger side of the vehicle--- not sure but what has been said-- might want to google it see what you can come up with
Thank you guys - very Helpful!
