Liked 112 Times in 31 Posts
Wondering what you guys are using with these cars? Trying to find something that doesn't need to much modifying to make work. Any ideas?
Rick Ryan |
Rick,
Terrance Smith from Florida, I thought you were gonna get back to me about the car....I got it ready to run in SS/IA or GT/EA, hope to hit the track with it around the first of the month and run at the race in Reynolds at the the end of July. Smitty oh as for brakes, I have the stock big 11 inch rotors on my car, have been looking into light weight alternatives but not sure what will work with 3300 lbs. |
#3 | |
Wilwood P/N 140-9054-D with the SRP rotors - About $775.00 http://www.wilwood.com/PDF/ds505.pdf or Lamb P/N #172A - $1280.00 $$$$ Terrance: You have a PM. |
Liked 883 Times in 237 Posts
Rick, You will have to swap out your spindles for ' 69 drum spindles for Strange discs, also for Wilwood,I believe. ....the early spindles also require the early tie rod ends also. .....Tom
Liked 26 Times in 13 Posts
I put the Wilwoods on my '71 by changing the spindles and outer tie rod ends. I used '68 drum brake spindles but I think any '67 to '70 drum spindles will work. Everything bolts right up, no problems, stops on a dime.
Bill Harris ex 2172 STK ex 2272 S/S |
Liked 364 Times in 138 Posts
I have just installed the Strange kit for 65-69 Mustang on my Maverick drum brake spindle. The only modification required was to change to larger bearings. The cups share a common o.d. and will interchange in the hub....the 71-73 Mustang spindle diameter is the same as the Maverick I believe.
Dave Turner SS/GT #1153 |
Liked 56 Times in 21 Posts
i have a 71 mustang and it had drum brakes
i put aerospace on and they are great did not have to chance anything vic guilmino 71 mustang 429 scj
Vic Guilmino 1129 STK |
