Old 06-21-2008, 10:56 PM   #1
Tracy Robbins
Liked 25 Times in 11 Posts
Default Need jr. dragster help
I know this isn't stock/ss related but I need advice on tuning my son's jr. dragster. It has a raptor engine w/ a 28 mm slide carb. prior to the burnout the it idles about 3700-4000 after the burnout it drops to 2000 and acts like it's going to cut off. This thing has all kinds of jets...which one's need changing?
Thanks for any help!
Tracy Robbins
SS 9766
Tracy Robbins is offline   Reply With Quote
Old 06-22-2008, 10:10 AM   #2
krugracing12
Default Re: Need jr. dragster help
I had a similar problem, A friend that knows about Jrs threaded the cap where the cable goes thru and installed a threaded cable end holder with a lock nut to adjust the idle. that cable adjuster did a much nicer job of setting the idle.
krugracing12 is offline   Reply With Quote
Old 06-23-2008, 11:27 AM   #3
herbjr
Liked 83 Times in 32 Posts
Tracy call me, we can test it at piedmont anytime and I think i can fix it
herbjr is offline   Reply With Quote
Old 06-24-2008, 12:27 AM   #4
Tracy Robbins
Thanks Herb, when I get time to come and test I will take you up on that offer. Do you have jets for 28 mm carbs? I'll call you!
Tracy Robbins
SS 9766
