Liked 291 Times in 92 Posts
Was ordering a set of rings from Total Seal and they asked me I if I wanted my spacers gas ported. I had heard someone talk about the setup, but wanted to know if anybody had tried them before? TS gets about $240.00 for a set and for that price I would like some opinions. Thanks RJ
Liked 880 Times in 311 Posts
I don't know about Gas ported spacers but I've gas ported rings. Sounds like a good way to keep from reworking replacement rings every time you do a freshen up.
Adger Smith (Former SS) |
I've known a few that have gone this route. Seems to work.
This is another one of those ideas that while legal, just make the racer spend more.
Jeff Lee 7494 D/S '70 AMX |
I just talked to Adrian Pendergrass @ Precision Measurement Supply (210-681-2405) and he makes a fixture for doing them yourself. $140.00 and includes the Carbide End Mill. That way you only need the spacers ($30.00) and you can make all you want. Mill access would be needed. Give him a call and check out his web page Precision Measurement Supply.
Liked 3 Times in 1 Post
RJ, i have been using them for a while and i had to machine my own spacers, now they are machining them and yes they do work!
Woodro Josey 2002 STK |
Appreciate all the info everybody, I am going to try them. Thanks RJ
Liked 166 Times in 46 Posts
R.J.
Back in 1961 there were some Mercury pickups built in Canada that had an FE engine with gas ported pistons. They were also equipped with a C-4 transmission. I would petition the NHRA for the rightfull parts that should be superceded for your car based on that truck from 1961 so that you can just run a gas ported piston instead of all those high tech expensive ring spacers. Jim C. |
#8 | |
Chad Rhodes 2113 I/SA |
