Old 08-09-2008, 10:24 AM   #1
Chris Cogan
Chris Cogan's Avatar
Default 842 BBC Heads
Does anyone know what a set of factory 842 heads might be worth? They were cast in 72, prepped by RHS and campaigned in the early 70's in an IHRA stocker. Also, has anyone done any dyno/on-track comparisons between the 842 vs. the new 401? Thanks!
Chris Cogan
Kaizen Motorsports
Chris Cogan is offline   Reply With Quote
Old 08-09-2008, 11:07 AM   #2
Mike Fuller
Liked 203 Times in 80 Posts
Default Re: 842 BBC Heads
The 842 heads should be used for a restoration. The 401's flow much better and are probably a lot cheaper. Put the 842's on Ebay and start with at least a $1200.00 reserve.If they are in nice shape they will go higher than that.I tried the 842 's back about twenty years ago and worked my tail off just to get them to run 3 tenths under the index.
Mike Fuller 396 STK
3961 SS
Old 08-09-2008, 09:36 PM   #3
Chris Cogan
Thanks for the feedback Mike.
Chris
Old 08-10-2008, 11:29 AM   #4
Doug McCue
Liked 13 Times in 2 Posts
What kind of flow figures do the 401's show in a stock configuration?
Doug McCue is offline   Reply With Quote
Old 08-10-2008, 03:49 PM   #5
Conway Witten
Conway Witten's Avatar
Chris,
Are you related to Vern Cogan? If you are email me at wconwayw@bellsouth.net
Conway Witten
Conway Witten is offline   Reply With Quote
Old 12-25-2008, 08:35 PM   #6
Jim Hanig
Liked 99 Times in 49 Posts
Doug the 401 s that i have flowed are 300 on the intake , about 10 hp better than the 291s. Jim Hanig
Old 12-26-2008, 12:41 PM   #7
Doug McCue
Jim you have a PM
